Old 12-03-2009, 06:10 AM   #1
d1nzfe
Drives: 1NZ-FE
Standalone ECU
Anyone on standalone ecu?
What is the setup? Do u still leave the stock ecu for controls of air-con and fan?
Is there any plug and play harness for 1nzfe?
d1nzfe is offline   Reply With Quote
Old 12-03-2009, 10:08 AM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Cali Yaris has a standalone ecu
Old 12-14-2009, 03:23 PM   #3
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I am standalone and the stock ecu is used for dash control lights and air-compressor control (air-con removed mine) etc...
Don't know what fan do you mean? dash or radiator fan?
Radiator fan must be connected with the ecu aswell
Parmas is offline   Reply With Quote
Old 12-14-2009, 05:04 PM   #4
Brad D
Drives: 07 Yaris RS 3dr
Most stand alones will run the dash and fans, ac ect... but not many can control the drive by wire TB..
Brad D is offline   Reply With Quote
Old 12-15-2009, 07:38 AM   #5
d1nzfe
Drives: 1NZ-FE
any reviews from you on your ecu yet?
Old 12-15-2009, 10:43 AM   #6
I'm running AEM EMS.
It runs radiator fans, electric water pump, water/meth injection and all engine parameters.
Also, have a 2-step rev limiter with anti-lag set up.
My A/C is out and I'm on cable so it doesn't manage those things.
Old 12-15-2009, 01:36 PM   #7
Parmas
Parmas's Avatar
Until I am confident that this ecu works great I will not post any reviews just yet. Although there is a good probability this one works fine.
Although If you have any questions on mine just ask!
BTW why do you need a standalone ecu? Tell us some info on you mate!
Old 12-23-2009, 12:37 AM   #8
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
hello dave :)
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 12-23-2009, 03:32 AM   #9
upgradedyaris
Drives: Yaris & Supra
MoTeC anyone? ;)
upgradedyaris is offline   Reply With Quote
Old 12-24-2009, 04:25 AM   #10
1nz
Drives: Vios
Apexi PowerFC available for NCP91
http://www.brashboy.net/superchager/main.html
Please visit us @:
greddyvios.blogspot.com
1nz is offline   Reply With Quote
Old 12-24-2009, 05:56 AM   #11
upgradedyaris
Meh, doesn't have great features.
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Yaris has a learning ecu? YogiYaris Performance Modifications 9 05-30-2007 07:03 PM
