| View Poll Results: 60K service due on Yaris 2007 | |||
| Take it to a Toyota dealership, they know what to do |
19 | 44.19% |
| Take it to the guy around the corner, he's probably more honest |
17 | 39.53% |
| Doesn't matter, it's all the same |
7 | 16.28% |
| Voters: 43. You may not vote on this poll | |||
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
My cute little Yaris LB is getting close to needing her 60 K miles service (still works like clockwork, as far as I can tell!
) Since I bought the Yaris at a Toyota dealership about 50 miles from my home, I decided to look into the Toyota dealerships closer to my home instead, for service. But when looking at the reviews for the various Toyota dealerships on Yelp.com , I saw that people complained quite a bit about the service they at the various Toyota dealerships (including the one I bought the car from) and frankly, it's a bit scary. I know you can't take everything people say at face value, but on the other hand, there is no smoke without fire either, and all these people cannot be entirely wrong. So, I was thinking. There is a small shop not too far from me who has a really good reputation dealing with foreign cars, and perhaps he could do the 60K service for me instead of going to Toyota? What do you guys think? Pros and cons of taking the car for service at the Toyota dealership, anyone? (At 60K, I'm obviously out of the intial manufacturer warranty but I still have powertrain warranty for a little while, if that matters). Thank you for all the input. |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Tell us what is in the 60k service. And tell us how much is either charging.
*looking at a flier for local dealors of their 30k service, also a 60k service. The main stuff is an oil and filter change, tranny fluid change, coolant change, spark plug change, and timing adjustment. All the other stuff I call fluff (expensive fluff) is "inspection" items. Our spark plugs are due at 100k and I think our coolant doesn't need change until 100k. So will they prorate for that? I don't think so. Two dealors here charge 270 and 250. They won't be able to weasel out of anything, you have a service record from the outside shop.
#3 | |
I think I also got coupons in the mail from 2 different Toyota dealers for various services, so I guess I have to sit down and do the math. I just don't like reading stories about people getting stiffed, getting poor service, etc. doesn't make me feel too confident.
Also think of it this way:
You're about to run out of warranty anyway or near it. Take this opportunity to "shop" for a decent mechanic you can trust. Instead of taking your car out to a Jiffy lube for that oil change, take it to a particular shop.... let them do the small things and rate their work. Keep going to the same shop if you happen to like their service and quality of work, this helps you to build rapport. When the time comes for a big job, you will want someone whom you trust. While big shops may treat you like a number, the small shops who knows you will give you that much better service and for less. I know one large truth, a good, honest mechanic is hard to find.
Drives: 2008 Yaris Join Date: Oct 2008
My only complaint about Dealerships is that when they change the oil they added PRECISELY the recommended amount of oil, no more or less. You end up never getting all of the oil out of the crankcase, which means you get over filled.
Aside that I've never had a cause from complaint from the Dealership. Gene |
Here is what you're supposed to do at 60,000 miles or 72 months :
Replace engine oil and oil filter Rotate Tires Replace engine air filter Inspect the following: - ball joints and dust covers - brake lines and hoses - brake linings, drums and brake pads/discs drive belts - drive shaft boots - engine coolant - engine valve clearance - exhaust pipes and mountings - front differential oil - fuel lines and connections - fuel tank band and fuel tank vapor vent system hoses - fuel tank cap gasket - radiator core and condenser - steering gear box - steering linkage and boots - transmission fluid or oil |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
If you are really concerned about the remaining warranty go to the dealer. But as I have posted on some of the threads about extended warranty, my local mechanic is a friend of more than a dozen years and his children goto school with my son.
I feel better paying someone I know the few times that I need to, than spending more with any large corporation. I would second the opinion to use the opportunity to find yourself a good mechanic. Get a referral or two, or look up a few places up on CarTalk.com Take it in for state inspection or basic fluid/filter changes and see if you like the way you are treated. In my mind `factory certified' is not necessarily better than work from an `ASE Certified' mechanic. Take some time and try to find someone you really like, and then you will have that backstop when you get to 4 X 60K and beyond.
![]() ![]() ![]() Drives: S Flint Mica Join Date: May 2006
It really does not matter as long as you have faith/reliability in the service mechanic doing the work. For my Yaris, I have used the Toyota dealership 100%. But I have used them for the past 20 years and have liked the results and bill $$$.
Kevin |
![]() ![]() ![]() Drives: toyota Join Date: Feb 2009
miles for tranny fluid change?
1st gen FTW
The Yaris owner's manual has no scheduled AT fluid changes.
For the Camry and other cars that use a Toyota AT it's 60K miles, using Toyota WTS fluid. I plan on changing mine every 30K miles since I do "pulse 'n glide" and sometimes hammer the poor thing. I consider this "Hard Use". Gene |
#11 | |
1) Independent Guy around the corner, for the 60K service, as descrived above: $100 even. Told me the chances of him finding anything wrong with the car during the inspection are next to nul. 2) Dealership No. 1 (where I bought the car, under their Certified program): first quote was ........... $540 !!! (same service, but they top all the fluids and look at the battery as well). I argued that this kind of service was already done not long ago when I bought the car under their "Certified" program and I've only driven the car 2000 miles since then, if that, and they eventually dropped the price to $135. 3) Dealership No. 2 (closer to where I live but with bad reviews on Yelp): $129 because they're having a special right now. 4) Dealership No. 3 (a little further, also bad reviews): put me on hold for a long time ... then I hung up. 5) Oh, and just for the sport of it, I went to another independent mechanic, about 10 miles from where I live, pretty highly recommended on Yelp: Their price (they were thorough and gave me a computer print-out of what Toyota requires them to do for a Yaris that age, at that mileage (which is the same as what I typed above) $200. Hmmmmm.... By the way, I have a Manual Transmission if that makes a difference. Last edited by tomato; 07-10-2009 at 10:24 PM. |
#12 | ||
Dealor one only lowered after you complained, the other had a special price. The Indie Mechanics average from 100-200 at the top end and those are regular prices. The poll is still too small a sample and many did not post why in either case. If you are still unsure, take advantage of the lower dealor prices and keep this list to use for an oil change, try those two Indie mechanics for your next oil change after the 60k service. The dealors have higher bills to pay than the local machanic but Dealor one shows that they still have room to work with.
#13 | |
Dealer one lowered the price but also some of the service as well. I know what you mean, I wish people had said "go to the dealer because" or go to the indie guy because" I guess I'm not really worried about who's going to do the oil change but I'm already thinking ahead about who's going to take care of my car. I don't really know a good mechanic around here. I used to go to a Honda guy for years (that's why we kept buying Hondas and bringing them to him) but eventually he retired. I've tried various places but never could find that person you really trust, you know.
#14 |
Yep. I finally found one here because he was the friend of a friend whom she worked for. So she knows how my mechanic works. I went the first couple of times and he was honest about things, his prices were low enough and he still allowed haggling on the prices.
Good luck man. hmmm... let me see if another friend who lives up in San Fran knows any good shops.
#15 | |
#16 |
Audio Junky
other than checking to make sure stuff isn't wearing out (brakes, etc.) there shouldn't be anything special about the 60k oil change.
Trans fluid & radiator fluid are supposed to last 100k or longer I believe, so there really isn't much to be checked... |
#17 |
It takes about half an hour to do the 60k service BTW. As far as dealers go my daughter just had a problem with her 99 Camry and took it to the dealer. $3200 they said. My brother in law fixed it (broken exhaust manifold) for $800. Dealers are total rip off artists. Going to them for anything is like putting a naked new born baby in front of a wolf.
#18 |
Half a Bubble Off Plumb
I generally agree with Bronsin. Dealers' shops are best avoided.
| I don't know why but my area my customer never appreciate good service | YarisSedan | Off-topic / Other Cars / Everything else Discussions | 12 | 02-27-2009 10:26 AM |
| Funny Business at the Toyota Service Centre | *MAD DOG* | DIY / Maintenance / Service | 10 | 01-10-2009 12:47 AM |
| Someone Please Help With SET & Local Dealer Nightmare! | sanityassassinv2 | General Yaris / Vitz Discussion | 32 | 11-26-2008 11:32 AM |
| 30,000 mile service: owners manual vs Dealer "recommendations" | yaristotle | General Yaris / Vitz Discussion | 7 | 11-20-2008 10:41 AM |
| Metro Atlanta Dealer Service Experiences | redyaris | Southeast | 2 | 03-21-2007 03:59 PM |
