Old 08-05-2009, 08:01 PM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
1NZFE Safe REV limit
I am considering to finally make a total tuneup to the engine on dyno. Here the tuners do not know much about the 1NZFE engine so I ask here what is the max safe rev limit to the engine?
(Remember that I am standalone )
Parmas is offline   Reply With Quote
Old 08-05-2009, 10:20 PM   #2
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
I know that stock is 6500 rpm's. Gram is setting his at 7000 rpm's I bellieve. So I guess somewhere around there would be good.
Old 08-05-2009, 10:45 PM   #3
there is a fuel cut around 6500rpm normally, but i wouldnt try going too much higher than that....maybe 6800....
Old 08-06-2009, 12:40 AM   #4
lilredrocket
Slowy getting there
Drives: 08 Liftback
Hes on a standalone he has probably changed all that or will when he decides on a red line
Old 08-06-2009, 02:10 PM   #5
Parmas
Parmas's Avatar
What can you comment about this GARM?
Old 01-08-2010, 10:37 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I know from experience that the motor will not spin to 8600 due to a missed shift. Somehow went to 2nd from the top of 3rd instead of 4th.
The motor survived but had 3 mushroomed valves.
Old 01-08-2010, 11:43 AM   #7
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I've seen like 5 of my friends miss-shift from 3rd to 2nd... thats why I granny-shift 3rd-4th
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 01-08-2010, 11:49 AM   #8
My head is ported and polished, but otherwise stock, no work to the cams or valves. My redline is set at 7200.
When you tune, just look for the power band, that will determine your redline. Higher is not always better. On my tC, it quits making power at 5800, so there's no need to set a super high redline on it.
Old 01-08-2010, 12:05 PM   #9
thats true
with intake and res-back exhaust, im past peak whp with stock redline...
Old 01-08-2010, 05:20 PM   #10
Porting and polishing you head does not change your max redline.
right. my point was that i have NOT modified my cams or valves, and that the car doesn't make power past 6500.
Old 01-09-2010, 01:17 PM   #11
Parmas
Parmas's Avatar
Originally Posted by cdydjded View Post
Porting and polishing you head does not change your max redline. Based upon your dyno sheet & the barber's dyno sheet our engines make max HP @ 6000rpm and start to loose power beyond 6500rpm. The reason is the camshaft specs specifically duration. IMO you do not need to be anywhere near 7200rpm. IMO 6500rpm should be you redline.
What if one own the Gude head?
Old 01-09-2010, 02:49 PM   #12
Ask Gude?
Old 02-09-2010, 08:28 PM   #13
Giupo
Drives: Yaris
these are the oem camshafts value :
Engine: 1NZ-FE
Valve Timing
>Intake<
Open -7° ~ 33° BTDC
Close 52° ~ 12° ABDC
>Exhaust<
Open 42° BBDC
Close 2° ATDC
Intake durations : 225°
Exaust durations : 224°
Giupo is offline   Reply With Quote
Old 02-09-2010, 11:17 PM   #14
The point remains the same. It's wherever the car stops making power. I can't imagine a build on the 1NZ that would require 8k or 9k rpms, so the question doesn't hold much relevance for me.
besides camshafts, you better have springs and some other head work done to access higher rpms safely.
Old 02-10-2010, 07:58 AM   #15
Parmas
Parmas's Avatar
Could you share your opinion what do you mean by better springs? or else what springs do you recommend
Old 02-10-2010, 11:47 AM   #16
better springs = stronger or "high pressure" springs
I don't have a recommendation, I have stock springs and I'm happy with my results so far. I see no need right now for higher revs - the car doesn't make more power up there.
Old 02-10-2010, 05:27 PM   #17
Parmas
Parmas's Avatar
In the microimage forums you mentioned in your thread (on last page 7) that art used stronger springs. Are you sure they are stock?
Old 02-10-2010, 05:52 PM   #18
yep, they are stock. I was wrong. :(
EVERYONE PLEASE STAY SAFE! Shroomster Off-topic / Other Cars / Everything else Discussions 5 01-01-2009 05:47 AM
CEL blinking during rev limit hit. ddongbap General Yaris / Vitz Discussion 2 10-01-2007 02:10 AM
Hyper Rev: Vol# 108 Vitz (No. 3) **IN STOCK & READY TO SHIP** KamiSpeed Sponsors Classifieds Area 1 03-03-2007 01:50 PM
