Old 02-23-2010, 01:57 PM   #1
peposhi
Drives: Toyota Vitz '03
Strong vibration when accelerating... why
Hi, lads
I've just traded in my Honda HRV for Toyota Vitz 2003, jap import. It's automatic, 5-door, 1.0L. It's lovely, calm car, drives very smooth and it's very comfortable. However I've noticed something strange. When going over 60km/h and pushing accelerating pedal, the front of the car starts vibrating very hard, literally shaking (please, excuse my English). Once you take off your foot of the pedal everything goes absolutely normal. Any time you push the pedal and accelerate the shaking appears and disappears once you lift your foot or just not push hard...
Why is that happening?
peposhi is offline   Reply With Quote
Old 02-23-2010, 04:25 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
It could be a couple of things , ie the transmission oil filter is blocked ,bad bearing in gearbox,
engine misfire , bad wheel bearing ,etc
it's one of those problems you need to hear and see for your self .
Old 02-23-2010, 11:05 PM   #3
peposhi
The car has not been driven for a long period and before I got it I saw the mechanics removing, fixing whatever was there and putting back the part connecting both wheels and steering mechanism. Like I said, the car drives very smooth, no noise at all when going over bad road surface. The only issue is that vibration when accelerating above 60km/h. It remains until 100km/h and then seems to be fine. And always disappears when you lift your foot or just release the pedal. I'm going to check it tomorrow morning with a friend of mine.
Old 02-24-2010, 02:30 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
sounds like a tyre ballance issue , or a half shaft out of ballance
Old 02-24-2010, 02:34 PM   #5
peposhi
I went to a mechanic today. He's said that I have to replace 2 drive shafts and an inner ball joint( not sure for the name of the second one). Original Toyota parts 571 Euro each shaft... Shocking news...
Old 02-24-2010, 02:53 PM   #6
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Get them from a breakers yard, if you can. Easy stuff to change.
Old 02-24-2010, 03:08 PM   #7
peposhi
Checked that too... it'll be 70 euro each... But I'm worried to buy second hand parts.
How could I check if my car is 00-03 or 03-06 model?
What is the difference
Old 02-25-2010, 07:52 PM   #8
peposhi
Problem was drive shaft, got it replaced, now runs fine. Thanks lads
Old 02-25-2010, 08:29 PM   #9
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by peposhi View Post
Hi, lads
it is an axle. just saw you got it fixed nm lol
Ptuning.com
Blown_xa is offline   Reply With Quote
2000 R.P.M Vibration dallas General Yaris / Vitz Discussion 35 09-01-2025 09:18 AM
steering wheel slight vibration high speed??? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 10-01-2012 06:36 PM
NST Crank Pulley Reliability? WeeYari Performance Modifications 59 02-10-2010 01:20 PM
How much engine vibration is normal? Frankd1 DIY / Maintenance / Service 6 10-14-2009 09:11 PM
Post-rotation vibration kurokoma-kun Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-15-2007 05:02 PM
