Old 02-21-2010, 10:37 PM   #1
curtqn
Drives: Toyota Yaris
Stick shift at 'N' at stop lights(Auto trans)
I'm driving a 2009 Yaris auto trans. At stop lights I usually shift the stick up to 'Neutral'.
Is this a good idea? . Can I save gas, brake pads, engine wear by doing this.
Does it cause any damage?
Thanks.
curtqn is offline   Reply With Quote
Old 02-21-2010, 11:02 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Probably saves a miniscule amount of gas, by unloading the idling engine.
Old 02-21-2010, 11:21 PM   #3
b_hickman11
Drives: 08 Sedan
Thanks.
It won't save brake pads.
Old 02-21-2010, 11:24 PM   #4
djct_watt
Drives: 2010 NCP91 5spd
Actually, if you've been heavy on your brakes and hit a stop light, you may in fact WANT to shift to neutral. If you've cooked your pads to the point of fading, leaving the brakes depressed while stopped keeps the pads in contact with the rotor, possibly causing the rotors to warp. Even if it does not warp, you are not allowing air to enter/escape between the rotor/pads to help radiate away the heat.
Keep in mind, under normal driving, this doesn't really apply. But if you've been driving aggressively, it's a good idea to help those brakes cool off as much as possible.
Old 02-22-2010, 01:52 AM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
It's an automatic transmission. Since it's automatic, why not let the transmission do its job. It's not semi-automatic.
Old 02-22-2010, 02:04 PM   #6
b_hickman11
Drives: 08 Sedan
Only if you are on a completely flat surface. Otherwise you would start to roll forward or backwards.
Old 02-22-2010, 07:29 PM   #7
djct_watt
Well, yeah... I'd hope people had enough sense to not do that if the car rolls. And if the brakes are cooked and the car does roll, the parking brake can also be used to hold the car at a stop light. Rear brakes aren't as loaded as the front, thus they do not heat up as much.
Old 02-22-2010, 07:36 PM   #8
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
also you should be able to switch to neutral from drive just by flicking the shifter anytime i use to do this on my previous automatic cars..
Old 02-24-2010, 02:45 AM   #9
curtqn
If "shift the stick to neutral" to much will this shorten the life of the neutral switch( at the transmission box)?
Old 02-24-2010, 09:41 AM   #10
kazama82
Drives: VIOS
should not be a problem..i do both on manual and auto transmission all the time..
kazama82 is offline   Reply With Quote
Old 02-25-2010, 12:43 PM   #11
Astroman
Modded Moderator
Astroman's Avatar
According to my scangauge II putting the auto trans in neutral while stopped with the brakes on my car uses .04 to .15gph less. I do 70-80% city driving and it helps with saving gas. I now have over 77,500 miles and my transmission is fine. I'm also less likely to roll forward if my foot slips off the brake.
Old 02-25-2010, 01:02 PM   #12
127.0.0.1
it can save between 0.015 and 0.075 gph depending on engine conditions and tranny temp
astromans numbers are correct as well. things vary with conditions, temp,
sometimes more and less too...
Old 02-25-2010, 05:30 PM   #13
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
just for kicks... whats the engine load (LOD) at when in gear, but stopped and foot on the brake? Whats the load when in neutral?
Old 02-25-2010, 06:27 PM   #14
sailbob
Drives: 2008 Toyota Yaris
Hot Brakes
I used to have problems with warped rotors, until I started letting the car creep slowly forward in gear but using the brakes. This spreads the heat from the hot pads slowly around the rotor and prevents heat distortion in only one area. Of course you have to allow room when stopping for this sort of thing.
sailbob is offline   Reply With Quote
Old 02-25-2010, 07:04 PM   #15
127.0.0.1
cold n around 41 --- in-gear around 56-58 ac adds 5 or 6
warm n around 31 --- in-gear around 38-39 ac adds 3 or 4
decel lod n is higher than in-gear decel
Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! TWM Performance TWM Performance 13 09-29-2009 11:55 AM
TWM Performance weighted shift knobs on sale! TWM Performance TWM Performance 5 06-30-2009 10:58 AM
New shift knobs available from TWM Performance! TWM Performance TWM Performance 3 06-25-2009 05:24 PM
A stick shift without a tach? dulcidude DIY / Maintenance / Service 29 01-07-2009 08:05 AM
October sale on TWM Performance shift knobs! TWM Performance TWM Performance 1 10-31-2008 06:01 PM
