Old 08-18-2009, 07:19 AM   #1
AFC Neo for simple fuel management
To continue our old discussion of approaches to tweaking the AF maps...
To recapitulate, the ECU has two distinct operating modes: Closed loop and open loop.
Closed loop uses the AF sensor in the header in order to make adjustments to the injectors duty cycle to keep the exhaust gases at a normal mixture. Tuning the AFR in this mode is rather difficult but could potentially be done by intercepting the AF sensor's signal and reporting to the ECU that it is leaner than it already is.
But what's of interest here today is open loop tuning. From PK's data logging runs, we saw that the ECU seems to go to closed loop mode once the throttle reaches about 75%. When it's in closed loop, the ECU uses a fixed internal map, and calculates the injectors duty cycle based on RPM and MAF sensor signals. Thus in theory it is possible to make adjustments to the MAF signals in order to tweak the resultant AFR. This seems to be the way Blitz's fuel controller for the supercharger kit operates.
So what would be useful is a tuning tool that can adjust the MAF signal only once a certain throttle percentage has been reached. I've done some looking around and Apexi's AFC Neo seems to fit the bill.
http://www.apexi-usa.com/products/?id=5347
Two adjustment modes: Hi throttle and Lo throttle, with the ability to select the throttle percentage for each mode (i.e. we'd set Hi Throttle at 75% and make adjustments there, while leaving the Lo throttle mode at default unadjusted values)
up to 50% signal adjustability, plenty of headroom
It also has a mode to cancel out the wrong readings that a MAF might give when you close the throttle and blowback occurs, I think someone mentioned getting a CEL at a certain time because of this
Problem is, the device costs about $400, which is a bit hard to justify compared to just dropping in some bigger injectors. But, it offers a degree of adjustability, even for the non-turbo'ed ones with a lot of other bolt-ons.
Old 08-18-2009, 11:31 AM   #2
Good find Thomas,
$400 is cheaper than $120-each injectors, until you add the tuning cost.
The two largest hurdles with our projects, IMO, is "who can tune this thing for me?" and "is it plug 'n play?"
Old 08-18-2009, 11:59 AM   #3
Good find Thomas,
true true... but with a wideband (which you should have anyway), you could probably self-tune it little by little. Like I said, we don't need super adjustability for a smallish project, just an easy way to dump more fuel when required.
I have not found an actual wiring diagram but it seems about as plug and play as the Blitz fuel controller, not a whole lot of wires to splice...
Old 08-18-2009, 12:04 PM   #4
mrbond
mrbond's Avatar
So, if I'm reading all of this correctly, this would be a way to tune the A/F ratio for both boosted and non-boosted cars? So those of us with all bolt on things like a CAI, 1ZZ TB, header, pulleys, and header-back exhaust would be able to tune the car to optimize HP gains for each modification? If so, that's not bad at all for the price...until, like Garm says, you get to the tuner. But even so, still not bad.
- A Toyota Yaris
- A whut Yaris?
Old 08-18-2009, 12:59 PM   #5
Yes exactly... I only have a narrowband AF gauge but if it is to be trusted, I can see my car runs very very rich at WOT, down to 11:1 sometimes... there's certainly a few horses to be gained from leaning that out a lil!
Old 08-18-2009, 01:09 PM   #6
mrbond
mrbond's Avatar
Wow, then this is really an excellent find!
- A Toyota Yaris
- A whut Yaris?
Old 08-18-2009, 01:19 PM   #7
now who's got $400 to give it a try?
Old 08-18-2009, 01:27 PM   #8
mrbond
mrbond's Avatar
Well, as for me, this would have to wait till about december (christmas money, etc). Now, Thomas, would one be able to feasibly tune their own car using a wideband gauge?
- A Toyota Yaris
- A whut Yaris?
Old 08-18-2009, 01:32 PM   #9
heh... I certainly don't know enough to give you any specific instructions
Old 08-18-2009, 01:36 PM   #10
mrbond
mrbond's Avatar
Well, we'll just have to wait and see, then.
- A Toyota Yaris
- A whut Yaris?
Old 08-18-2009, 01:44 PM   #11
well here's a good read:
http://www.diyautotune.com/tech_arti...squirt_ems.htm
Old 08-18-2009, 02:42 PM   #12
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
AEM FIC is cheaper
Originally Posted by xnamerxx
you nailed it sir.
Old 02-25-2010, 03:15 AM   #13
johnsmith12709
Drives: good
Yes you are absolutely correct.....
http://www.prodigyapex.com/
johnsmith12709 is offline   Reply With Quote
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-03-2026 12:44 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 03:35 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
Standalone Fuel Management System Jujufruit Performance Modifications 5 08-24-2007 01:37 PM
