Old 02-26-2010, 09:22 AM   #1
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
noob question..
hey fellas...
i just placed an order for some lowering springs and other goodies from Garm, my brother thinks its a bad idea because it could mess up the tranny..has anyone ever encountered a problem with their suspension or trans? im just a lilttle hesitant if it could cause some problems...any suggestions for the noob? lol..it would be greatly appreciated.
thanks!
msfire671 is offline   Reply With Quote
Old 02-26-2010, 09:34 AM   #2
Your brother on crack? lol
Old 02-26-2010, 09:44 AM   #3
hatchbackkid82
Drives: .
I heard of something like that on another forum. The guy lowered his car and trans went out shortly after. He replaced the trans, and that one went out. He replaced it two more times afterwards with the same result. He took it to a mechanic and the mechanic said it was b/c it was too low and something about the axle angle. This was on a CRX
You should be ok though, i've lowered every car i had and never had a trans go out on me.
Old 02-26-2010, 10:25 AM   #4
msfire671
msfire671's Avatar
ahhh..i see. well thanks for the reply guys.
Old 02-26-2010, 10:26 AM   #5
Never heard of a single problem with springs and the Yaris.
Old 02-26-2010, 10:26 AM   #6
heeroyuy01195
Post count means nothing.
that usually only happens if you slam the car to the ground incorrectly, if you just bought lowering springs, most are around 2" drop max so you'll be fine.
Old 02-26-2010, 11:08 AM   #7
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
+1
The kind of drops you get with these sorings will not hurt your tranny at all. That only happens when people cut springs drastically and put strain on the driveshafts where they weren't meant to have it.
What these springs do is lower the center of gravity, but the forces on the axles are identical to oem suspension. You'll be fine, and your brother will be jealous.
Old 02-26-2010, 11:21 AM   #8
127.0.0.1
the worst it can do, if installed correctly, is create excessive wear on the CV's
from the 'non-standard' angle of the propeller. 1 inch in these little CV's are ok,
but 2 inches would wear them out faster (YMMV)... but tranny problems ? I doubt the actual
transmission is affected
Old 02-26-2010, 12:24 PM   #9
DerFlosser
DerFlosser's Avatar
Drives: Yaris
correct....
DerFlosser is offline   Reply With Quote
Old 02-27-2010, 12:58 AM   #10
msfire671
msfire671's Avatar
i am so relieved! lol...thanks guys!
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 10:44 AM
Noob Question 8thcivic07 General Yaris / Vitz Discussion 3 12-11-2009 12:04 AM
noob question... wowitswil Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-19-2009 03:40 PM
Maybe a noob question but help me please. JWALK36 In Car Entertainment + Electronics (audio / video / alarm) 2 06-29-2009 10:41 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
