Old 10-04-2010, 10:22 PM   #1
bhola
Drives: 2007 Yaris
2007 Yaris Door Lock Issue
Hi Folks,
I bought Toyota Yaris recently and have issue with driver side door lock. The car lock fine but key open door intermittently. The key works great on passenger side and also tried 2nd key and same issue.
I thought i look around for quick DIY for lock so does any one have see this problem and know quick fix?
Also if have to replace lock is this something I can DIY? If so appreciate if you can share procedure.
Thanks for your help!
bhola is offline   Reply With Quote
Old 10-04-2010, 10:47 PM   #2
Does the key bind, where you can't turn it all the way, or does it turn all the way, but not unlock?
Old 10-04-2010, 11:04 PM   #3
bhola
Drives: 2007 Yaris
Sometime I can not turn key at all. If I can turn it lock works just fine.
Thanks
Old 10-04-2010, 11:09 PM   #4
Thanks
Have you tried a different key and/or lubricating the lock with graphite?
Old 10-04-2010, 11:14 PM   #5
bhola
Drives: 2007 Yaris
I have tried with 2nd key and same results. I did not tried lubricating. Any idea how can I do this? Do I have to take out door panel to lubricate lock and is graphite special brand of lubricant or any lubricant will work?
Thanks
Old 10-04-2010, 11:17 PM   #6
Thanks
You can pick up a little squeeze tube of powdered graphite at an auto parts or home center. You simply stick the tip into the lock, squeeze it a couple times, and then run the key in and out a bunch of times to distribute it.
Old 10-04-2010, 11:22 PM   #7
bhola
Drives: 2007 Yaris
Thanks. I will try it out and post the results.
Old 10-05-2010, 01:01 AM   #8
bhola
Drives: 2007 Yaris
This worked!! Thanks a lot for quick response and your help.
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 02:11 AM
