Old 03-06-2010, 05:12 PM   #1
3stars_n_a_sun
3stars_n_a_sun's Avatar
Drives: 2008 yaris sedan
clunking sound
hi all,
i would like to ask for your opinion on this, this occured last thursday. when i turn the car all the way to the left i hear a clunking sound coming from the left front part and i remembered that i ran on some big pothole weeks before. what could be causing this?
i need your expert opinions before going to the dealer (you know how dealers here in LA). btw, my car is still under warranty i hope they'll cover any replacing parts.
thanks.
3stars_n_a_sun is offline   Reply With Quote
Old 03-06-2010, 05:22 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Check your wheel nuts
and try moveing the wheel by hand while it is still on the ground
Old 03-06-2010, 05:42 PM   #3
3stars_n_a_sun
done. the wheel nuts are snug and fit
Old 03-06-2010, 08:21 PM   #4
Hershey
ball joint or tie rod end ?
Old 03-06-2010, 08:29 PM   #5
3stars_n_a_sun
how do we know specifically when to change the ball joint?
Old 03-06-2010, 08:45 PM   #6
Hershey
wheel haves to much play in the up and down movenent of the wheel . Too much play of wheel left and right is tie rod . A dealer service center could diagnose it . MIDAS and other national car shops will check it for free . Good luck .
Old 03-10-2010, 10:54 PM   #7
Boost Addicted
Drives: 2008 Yaris 5spd, 2005 GLI 1.8T
Clicking when the wheel is cranked all the way to one side (or the other) typically indicates a shot CV joint (also known as half shaft, or axle). Lift her up and see whats going on under there. Check for torn CV boots and leaking transmission fluid where the axle meets the transmission.
Note that just because you dont have either of these symptoms, doesn't mean that the joint isn't shot. You may need a shop to inspect it.
Boost Addicted is offline   Reply With Quote
Old 03-11-2010, 07:57 AM   #8
41magmag41
Drives: Loaded 2007 mica silver sedan
Maybe its the loose nut behind the wheel!! Just joking, I would check the tie rod and CV joint, then move to something under the fendor might be loose from the pot hole you ran over.
41magmag41 is offline   Reply With Quote
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
My other sound, suspension? N9QGS DIY / Maintenance / Service 2 10-19-2009 02:26 AM
weird sound when engine at around 2000 rpms soup1207 DIY / Maintenance / Service 38 06-05-2009 10:01 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
