Old 10-08-2013, 06:23 PM   #1
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Anyone with AT and a CAN sniffer?
Hi there,
I would like to use the unused parts of my instrument cluster, e.g. gear number by injecting packets on the CAN bus.
I have hardware to do so, however, I don't know anyone who has an XP9 with AT (it's rather seldom ordered with AT here in Germany).
I can't afford a gauge to fiddle around with (the one I'd like with VFD costs even used almost always at least 150€, about 200$; I guess the one with electromechanical tachometer would accept the same commands, but it would cost me still >50€ due to shipment costs), and even if I had one, I'm sure it would be a hard job to feed it manually with thousands of possible IDs before getting a reaction.
So I would like to ask if someone with an AT XP9 and a CAN sniffer (available at ebay from China for ~25€) would be so kind to try to find out where the gear information hides or at least make a log with the IDs used by the ECU
Hopefully someone can help me ;)
dj92 is offline   Reply With Quote
Old 10-08-2013, 07:45 PM   #2
I developed my own CAN sniffer and have reverse engineered a significant portion of the Toyota communications (beyond the simple OBD compliant comm.)
I can definitely help you out with this.
Old 10-08-2013, 10:09 PM   #3
OK - Here's what you can command the AT indicator to show. There is a 5 second timeout, so if you don't send another command within that time the indicator will go off.
blank 07C0:0530090000000000
L 07C0:0530090001000000
2 07C0:0530090002000000
3 07C0:0530090004000000
4 07C0:0530090008000000
D 07C0:0530090010000000
N 07C0:0530090020000000
R 07C0:0530090040000000
P 07C0:0530090080000000
5 07C0:0530090000020000
6 07C0:0530090000040000
7 07C0:0530090000080000
(CVT SPORT) 07C0:0530090000100000
(M) 07C0:0530090000200000
S 07C0:0530090000400000
B 07C0:0530090000800000
Old 10-08-2013, 11:40 PM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Old 11-11-2013, 07:46 PM   #5
nookandcrannycar
Yep. There is some old saying...I can't remember how it goes...but the gist of the saying is that one person knows so much more than anyone else that he/she has probably forgotten more about the subject than the sum total of the pertinent knowledge of all others*
* - Normally, this would 'be accurate without quite being hyperbolic (which is what I was shooting for), but this might be an accidental insult to the rest of us, as CTScott has probably rarely forgotten anything!
Old 10-09-2013, 05:49 AM   #6
dj92
Embracing Curves
dj92's Avatar
CTScott, you guy definitely rock!
Sadly, I could not manage to get it working yet with my CAN sniffer, maybe it needs some initialization.
However, I'll program my PIC32 and check whether it makes the job better than the crappy chinese software (sad to have to say it so)
Old 10-09-2013, 06:42 AM   #7
Just to verify, the 07C0 is what you have to set your transmitter address to.
I have a European digital cluster on hand. This morning I will try it with that to verify that it will respond to those same commands. I am fairly certain that it will, as it works as a direct replacement for the US cluster.
Old 10-09-2013, 07:40 AM   #8
dj92
Embracing Curves
dj92's Avatar
Yup, I set it that way.
I think the sniffer is innocent, I remember having injected packets where I got responses that made sense (the same like when I accessed some ECUs with Techstream)
Old 10-09-2013, 08:20 AM   #9
I just tried the European digital cluster and it does not support these commands. It supports ones where I can make all of the digits (including the speedometer and odometer) indicate the numbers 0-9, but not commands to just tickle the gear indicator.
For the heck of it try the following:
07C0:05300A0000200000 (should put the gear indicator as 9 and the odo as all 9's)
07C0:05300A0000400000 (should put the gear indicator as 8 and the odo as all 8's)
07C0:05300A0000800000 (should put the gear indicator as 7 and the odo as all 7's)
Old 10-09-2013, 10:49 AM   #10
dj92
Embracing Curves
dj92's Avatar
Yeah, I've already wondered why there was no way to control the gear display in Techstream, just the entire display test was available there.
Mine does not accept these above commands either, perhaps it wants to be initialized.
Edit: Nope, the sniffer's software punk'd me :D
Sadly setting the CAN filters is a pain in the a$$ with that cheapo software, but I can't afford a better one.
Quite funny that they omit features for the european versions.
Seemingly it's not just the cruise control (not even an indicator light in the cluster)
However, thanks for your efforts
EDIT: the gear commands are even rejected:
07c8 03 7f 30 12 00 00 00 00
Old 10-09-2013, 11:21 AM   #11
Interesting. I might have to work on getting you one of my devices to experiment with. It would actually be very handy for me to have access to data from European Yaris for comparison.
Old 10-09-2013, 11:25 AM   #12
dj92
Embracing Curves
dj92's Avatar
That'd be great!
I have already worked on some basic parameters which are easy to poke:
http://www.fingers-wiki.de/yarisforschung_xp9
Hopefully it's understandable for you ;)
If not, don't hesitate to ask me :)
It is especially about which doors are opened and whether the door locks are operated and especially in what direction and how (fob, lock on door, knob inside the car).
We have an entirely different engine controller here in europe (no cruise control), it might be just because I have the 1l engine (1KR-FE), on the other hand side I can't imagine that the european yaris with the VFD has a CC which would mean that it'd need a different cluster.
However, a friend of mine has a Yaris with the 1.33 dual-vvt-engine (from 2010 or 2011) where seemingly the same cluster as in the canadian Yaris is used.
IIRC it's an MT, just to mention it ;)
Old 10-09-2013, 12:54 PM   #13
That'd be great!
Very good - Those all correspond with ours as well. I am glad to see that the primary messaging is likely pretty much all the same.
In that case, when I have a chance, I will sniff out the packets from the ECM to the cluster in regards to shifter position, as they will likely be the same as well (even though the diagnostic mode packets were not).
Old 10-09-2013, 01:42 PM   #14
dj92
Embracing Curves
dj92's Avatar
Last night I also found this:
https://github.com/fabiobaltieri/toy...er/toyothack.c
I checked the 0x398 (fuel usage) and the values while driving seemed legitimate :)
However I still need to see how it's dimensioned
Edit:
New findings!
Techstream says A/D value of fuel sensor is 122dec, that is 7ahex.
I had a look at the log, and, surprise:
7c0 02 21 24 00 00 00 00 00 is the request
7c8 03 61 24 74 00 00 00 00 is the answer.
Task for those new to this course: find the location of the interesting byte :D
It looks like a pid-21-obd-command.
EDIT3: could also be 63 instead of 24.
further investigation to do.
EDIT2: Battery voltage is 144=14,4V =90hex
7c0 02 21 11 00 00 00 00 00 is the request
7c8 03 61 11 *90* 00 00 00 00 is the answer
More to come ;)
Old 10-10-2013, 12:10 AM   #15
OK - The ECM message to the cluster for the AT indicator is CAN ID: 03B4. A MT ECM still sends messages on this ID, so you have to frequently (~ every second) send your message to override the blank.
P: 03B4:0000324C80000000
R: 03B4:0000324C40000000
N: 03B4:0000324C20000000
D: 03B4:0000314C00400000
Old 10-10-2013, 03:10 PM   #16
dj92
Embracing Curves
dj92's Avatar
Sadly this wasn't successful, neither with the always crashing sniffer nor with the PIC32 :(
Seems like the ECU initializes the cluster in a special way or there are collisions because of the same ID.
The only way out would be a filter using two transceivers, but this would mean a critical modification to my car, so I fear that I reached a dead end :(
However, this does not mean the end of CAN bus research to me ;)
I'm about to build a bus node that plays a sound whenever the doors are (un)locked via fob :D
Way cooler than blinking ;)
Old 10-10-2013, 03:45 PM   #17
Did you by any chance sniff for 03B4 packets on your car? If you can find someone over there with an AT, it would also be interesting to see if 03B4 is used on European Yaris as well.
If you can find me a cheap AT ECM from a junkyard over there (here I can often pick up ECMs for under $50 from Junkyards) I can do much more analysis on my test bench. I have a complete and fully functional Yaris CAN bus network wired up on my test bench.
Old 10-10-2013, 05:16 PM   #18
dj92
Embracing Curves
dj92's Avatar
Here we go:
000003b4 00 00 24 b4 00 00 00 00
I'm afraid this is a hard job :(
Although the Yaris is quite common here (I see about 5 each day), it is quite hard to find used spare parts because it is still rather new.
Additionally, cars are more expensive here than in the US, and so are the parts.
I can only dream about a cluster for 50$...
Last but not least: AT is rare here, especially in such small cars it is ordered seldom.
Including anything from Mercedes A-Class over BMW whatever to VW Golf I had to do with up to now, just about 5% had AT.
I have had a look but did not find something acceptable, but maybe you're lucky:
(Fasten seat belts, I can't be held responsible for fallen out eyeballs )
http://www.ebay.de/sch/i.html?_sacat..._skc=200&rt=nc
If a seller doesn't want to ship to the US, I can of course do this for you.
Quite a nice thing
You used crashie parts, am I right?
One short extra question:
Do you, by accident, know how the PWM-dimmed dome light is switched?
I did not manage to take the ECU apart or at least out.
I expect a n-channel type Mosfet to be in there, but without any knowledge about the part number, I am unsure how much current I can let it switch without risking damage.
Of course, I could add an external transistor, but I like to keep it as simple as possible.
My plan is to stick LED stripes to the under the seat frames, just if you wondered.
@Management:
I hope the deviation from the thread title is tolerable ;)
