Old 12-12-2009, 09:37 PM   #1
birdman
Drives: '08 Blazing Blue Yaris LB
Cooper eater
What are the minimum mods I'd have to do to my stock automatic LB to transform it into a Cooper eater?
birdman is offline   Reply With Quote
Old 12-12-2009, 10:13 PM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
nitrous
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 12-12-2009, 11:48 PM   #3
JBIZZ
Drives: 2007 Liftback white
Either turbo or supercharger (The Blitz I believe is too underpowered)
Here are the weights of each vehicle which I found online through Yahoo answers & MSN. I think the Minis vary on year of how much they weigh.
Yaris 3-door, 5sp - 2295lbs
Yaris 3-door, auto - 2340lbs
Yaris 5-door, auto - 2340lbs
Yaris Sedan, 5sp - 2293lbs
Yaris Sedan, auto - 2326lbs
From 2002 to 2005 the coupe weighed 2315 pounds and the convertible weighed 2700.
From the 2006 Mini Cooper Owner's Manual, Data Section, Weights: Mini
Curb weight, with all optional special equipment Mini Cooper with manual transmission 2,524/1,145 lbs/kg automatic transmission with Steptronic 2,557/1,160 lbs/kg
Mini Cooper S with manual transmission 2,679/1,215 lbs/kg automatic transmission with Steptronic 2,723/1,235 lbs/kg
From MSN Auto Specs 2004 mini cooper S with manual = 2678lbs
So it seems it would be easier to beat a newer mini S than an older one. One has to realize modifications to Minis as well.
The automatic transmission may not be able to handle the power of a turbo or supercharger on the Yaris and will not make as much HP as a manual transmission. You will also need: lower compression forged pistons, forged piston rods, better clutch, bigger exhaust system, higher output fuel injectors, possible limited slip differential, & maybe stronger drive axles.
For the price of a Mini S, I believe one can make a faster Yaris w/ manual transmission. Don't know much about the Automatic transmission, but heard it can't handle as much power as the Manual.
JBIZZ is offline   Reply With Quote
Old 12-13-2009, 01:02 AM   #4
ddongbap
Skill. Coil overs. Tires. Balls.
Old 12-13-2009, 01:13 AM   #5
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
In a straight line, or?
Nitrous for a straight line.
Old 12-13-2009, 04:01 AM   #6
birdman
I think it would be cool to have a dead stock looking LB to roll up along side a Cooper and give a few revs to get their attention and dust 'em.
Old 12-14-2009, 12:01 PM   #7
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
you will need the following:
stock 1nz-fe motor
a 1/4 mile headstart
some kind of hallucination
seriously though, minis aren't that fast..
i spank them every time on my 21 speed...
Sponsored by: Micro Image
http://microimageonline.com
Old 12-14-2009, 12:29 PM   #8
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Even with mods, your gonna run into problems.
Coopers are built for the track, or at least built to handle in the corners.
Even with my mods, Coilovers, Rear Sway Bar, much wider tires (Ventus RS-2's) I think I would have a struggle even keeping up with a cooper.
Only real thing that can change from car to car, is the Driver and experience.
If you know how to drive your Yaris like a Vitzcup pro, you probably have a thing or two up on the average Mini driver.
Now if everything is neck and neck, mod for mod....driver for driver....Mini wins hands down every time.
Old 12-14-2009, 12:36 PM   #9
Sabretooth
37HSSV
Sabretooth's Avatar
https://axwaresystems.com/axorm/file...121309_raw.htm
Here are some results from an Auto X where 6 Yaris were there...
Plus some Mini's Cooper S's and regs.
Notice the times for the Cooper S was in the upper 40s. Garm in a Modded to hell Yaris (300whp) couldnt even get past the 50 second mark.
Now this could be due to too much HP on a wet track, but it depends, all variable.
Here are some times from Mini guys vs Yaris guys at a Cali Autox I have posted the classing they are in and their times. These are the actual documented times, from people that finished...There were Mini peeps that didnt finish, so I could only go with what was avail.
NOTE THE CONDITIONS WERE NOT PERFECT, LOTS OF WATER ON TRACK:
Yaris Squad:
NOVHS, 615 Garm Beall , Toyota Yaris - 54.010
HS , 425 Long Tri , Toyota Yaris -56.293
NOVHS, 226 Jesus Saucedo, Toyota yaris - 59.505
NOVHS , 616 Rob Huh , Toyota Yaris -59.944
NOVHS , 618 Aaron Snyder , Toyota Yaris - 60.305
NOVHS , 614 Joey Patel ,Toyota Yaris - 67.470
Cooper Squad:
SK2GS , 333 Kurt Rahn , Mini Cooper S - 49.592
SK2GS , 127 Adrian Covert , MINI Cooper S - 50.219
CST, 210 Michael Bradley , mini cooper s - 51.584
GS , 35 Chuck Waer, MINI COOPER s - 53.180
CSTL, 230 Sharon Malmen , Mini Cooper S - 58.823
Really without knowing who has what mods, youc an only go with the times...
But even Garm's Yaris only beat one finished Cooper S (And a chick was driving)
But with saying this, a Cooper regular might be 1-2 seconds slower than the slowest S, depending on driver. So it is possible for a good Yaris driver to hold their own.
Last edited by Sabretooth; 12-14-2009 at 12:50 PM. Reason: Making post easier to read....
Old 12-14-2009, 12:53 PM   #10
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
SELL IT and start with a different platform.....
Old 12-14-2009, 01:34 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
cooper and yaris both fall into H stock.
learn how to drive your car (at the track, not drag racing, that's not driving)
and quit talking about street racing, it's useless, and proves nothing.
Old 12-14-2009, 02:29 PM   #12
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Don't think you're going to get a Yaris to beat a Mini. The Mini is a sports car, the Yaris isn't. You can prep a Yaris to the hilt, but you can't do anything about the suspension design, which is the main weakness on the track/autocross course. You also have gearing to consider.
I love the Yaris and I can compete effectively with other drivers in better cars, but I can beat myself in Cooper S, by 2+ seconds.
The regular Cooper is the same story, but less HP. A bone-stock Yaris will get spanked by a Cooper. Once you make the Yaris more competitive with minor handling mods, you are no longer in H-stock.
All that being said, you can build a nicely-prepped Yaris for $10k less than a Cooper S will run you.
If you want the "best" performing car of the bunch, get the Cooper S JCW. I'd take on any prepped Yaris out there (FI too) on an autoX course in a stock JCW and fully expect to win.
Thing is, most people at the autoX events are nowhere near as good as the cars they drive, so a good set of tires, an alignment and LOTS of driving practice will still beat most cars.
Old 12-14-2009, 02:37 PM   #13
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Learning to drive it is the most important part. Garm was running about 220 hp in his estimation, and he admittedly isn't an autocross specialist. His times will get a lot better if he chooses to practice.
That is what you need to do to. Any real racing needs practice. You should prolly gut your interior first. Take everything out you don't need, including interior pieces and rear seat. You should learn to really drive, autocross helps.
If you are just talking about street racing, get the biggest turbo you can. Cash is king there, a great tune & at least 200 - 250 hp is the minimum.
And even then there is no guarantee. Who knows what mods a cooper would have.
Colin Chapman disciple
Old 12-14-2009, 02:53 PM   #14
ozmdd
ozmdd's Avatar
If you are trying to win at street racing, you are so hopelessly in the wrong vehicle that there isn't any real reason to discuss it. Sure, you can spend $10k making it into a 250 HP beast, but you'll still get whipped by a Mazdaspeed3 with some sticky tires. this is not a drag racing vehicle.
Old 12-14-2009, 02:57 PM   #15
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Seat time and luck.
Old 12-14-2009, 03:39 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
money spent on the overpriced JCW would go great into an S2000 that would hand the JCW its ass ;)
Old 12-14-2009, 03:41 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
You should prolly gut your interior first. Take everything out you don't need, including interior pieces and rear seat. .
worst advice ever, if you want to take autocross seriously.
taking out your rear seat puts you in SM, regardless of ANY of your other mods.
Old 12-14-2009, 04:29 PM   #18
Sabretooth
37HSSV
Sabretooth's Avatar
Class for Class/Part for Part, youll never be able to beat a Mini...The Yaris just wasnt built to do so.
Only way you can beat a Mini, is staying in H-stock, and trying to work within the rulebook to keep yourself "port-modded but stock", tidbit from Tamago...
Yet again a Mini could do the same thing, then your SOL
18 x 7.5 Konig Unknown rims with Cooper Zeon 2XS tires window_lee Items for Sale by private party 2 11-23-2009 08:46 PM
Thinking of trading Yaris for Mini Cooper S convertible. marcus General Yaris / Vitz Discussion 94 06-26-2009 08:38 AM
