Old 04-17-2010, 06:39 PM   #1
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
yakima double down help
ok so i recently got back into biking and i purchased the hitch rack. everything was going good for a while till the plastic bike cages are always loosening up. anyone with a fix to stop them from moving? im thinking electrical tape or plastidip around the cages to prevent cage from moving. just wanted to know if someone has a better idea. thanks.
staypuft is offline   Reply With Quote
Old 04-17-2010, 11:11 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Would electrical zip ties work?
Old 04-18-2010, 11:20 AM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
staypuft,
If you open the large fittings a bit they put pressure on the bar and stay put. If you make sure the smaller fitting's retaining rings are flush to the bars they will usually stay put.
If you drive aggressively while bicycles are loaded they will still move some, so take it easy.
Edit: These items are considered consumable, as are the rubber straps, so don't be surprised if after 2 years of heavy use you need to replace these things.
- Brian
Share the Road
Old 04-18-2010, 06:12 PM   #4
staypuft
aka SDMF
staypuft's Avatar
its been really windy and i usually go 55-60 while transporting my bike. usually the one with the stabilizer is ok the one that moves is the single one with the rotating lever
Yakima Roof Rack - $200/bro galaxyhillvt Items for Sale by private party 14 04-14-2011 09:45 AM
Is Yaris HB 2007 Double Din or Single Din? ediaz_pr In Car Entertainment + Electronics (audio / video / alarm) 3 04-09-2010 08:41 PM
Yakima Roof Rack for sale galaxyhillvt Items for Sale by private party 5 06-03-2009 02:00 AM
FS: Yakima Roof Rack System KG4GYV Items for Sale by private party 5 03-31-2009 11:23 AM
Yakima rails on hatchback gbrunner Cosmetic Modifications (Exterior/Interior) 4 08-23-2007 12:07 PM
