![]() ![]() Drives: Yaris RS 2009 5DR Join Date: Jul 2009
Anybody had rubbing issue and solved it ??
![]() Hi i'v lowered my LB yaris with Tein Coilspring last week It is now 1.9R 1.9F. I'm on 205/50r16 on 16x7 Slipstream +40 offset. My car was on Eibach Prokit 1.2'' Drop With No rubbing at all. After the installation of the TEIN Spring with the 1.9'' Drop, the tires rubs on the front inner fender when i take even small bumps. It rubs where the bumper connects to the fender. Anybody had a rubbing issue and solved it ? Thank you !!
Megan Racing Coilovers - HID 6000K - Fog Light 12 000K Blue - 50/70/90 Tinted WINDOWS - Short Shifter TWM - Rota Sliptream 16x7 Direzza StarSpec 205/50r16 - Injen CAI - R1 Concept Slotted Rotors - Carbotech Brake Pads XP8 - SS Lines - Sparco Steering Wheel - 23MM Rear Sway Bar - Ultra Racing rear, under and fender brace - Borla Axelback |
195/50/16
![]() ![]() ![]() Drives: 08 Yaris Join Date: Oct 2008
so you only used springs to lower your car and your shock/struts are still OEM. maybe your shocks are too soft to withstand and handle the extra weight. try getting stiffer aftermarket shocks as well
RIP Yaris, I will miss your superb handling a lot. darkmoon87's picture thread http://www.yarisworld.com/forums/showthread.php?t=10013 |
"Stealth Runner"
oh i want to see more pics of your 5door! it looks nice!
skinnier tires or stiffer shocks will solve your problem |
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
I lowered mine with df210's and TRD shock/strut, and on stock tires had no rubbing at all.
I went to 205/55/15's and that's when I started rubbing on bumps. These wheel wells aren't really built to hold anything over a 195 if it's dropped
#6 | |
I'll post few pics today after i wash it !! I like my 205 tires but i guess if i had bought 195 they would be more streched and would not rub. with 1.2 inch drop ( as seen on my signature picture ) there was absolutly NO rubbing at all thought. I was wondering if there was a way to modify the inner fender to stop the rubbing. I'll go to the junk yard buy two spare inner fender because mine are getting a little weak lol . Another thing ... if i go with stiffer shocks ! will the car handling be improved a lot ? I was also thinking of doing the mod discussed on the forum wich takes your rear axle a little higher !!
Here are some pictures I took from my 5DR lol . Here in Montreal i was impossible for me to have an 3DR RS Black.. I waited 2 months and i finaly got a 5DR but i'm happy with it !
When i took my spare tire out all my rubbing issues went away in the back and surprisingly even in the front.
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 07:37 PM |
