Old 06-26-2010, 05:19 PM   #1
landrym28
3,300+ at one point.. >:(
landrym28's Avatar
Drives: 2010 Hatchback RS
Bolt Pattern Question
Quick question. I did a quick search on this, and came up with nothing (believe it or not), but will rims that are 4x114 fit on the Yaris LB? Or do they need to to be 4x100 bolt pattern.
I was looking on Kijiji for some rims and I thought these looked pretty good.
http://saintjohn.kijiji.ca/c-cars-ve...AdIdZ199017824
Thanks,
Matt (who is nowhere close to being a tire expert!)
Old 06-26-2010, 05:35 PM   #2
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
4x100... I have a link at home I will post, but I'm at work for now.
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 06-26-2010, 07:21 PM   #3
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
The 4x100 refers the bolt pattern and bolt circle of the mounting holes. "4" refers to the number of wheel stud holes and "100" is the diameter of the bolt circle in millimeters.
A 4x100 is 4 holes on a 100mm circle
A 4x114 is 4 holes on a 114mm bolt circle
From one pattern to the other, the difference in distance between two opposing studs would be 14mm (~0.551")
So no, they won't fit directly. You can buy hub adapters that will bolt onto your existing hubs (4x100) and have new studs that are a 4x114 pattern. You will have to account for the hub adapter thickness when calculating which wheel offset to get.
Stove is offline   Reply With Quote
Old 06-26-2010, 08:00 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
Look here to answer many of your questions:
http://www.yarisworld.com/forums/showthread.php?t=5021
bolt pattern phenoyz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 01-05-2009 12:51 AM
bolt pattern??? anubisx99 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-15-2008 08:21 PM
yaris sedan bolt pattern phenoyz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 10-25-2008 12:19 PM
Do any other Toyota front seats have same bolt pattern as Yaris? ScottFern DIY / Maintenance / Service 18 07-02-2007 11:44 AM
Bolt pattern: Yaris Sedan littletegls Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 12-03-2006 05:29 PM
