Old 06-29-2010, 09:18 PM   #1
detroiter
detroiter's Avatar
Whats the best auto trans fluid and why?
Want to see what everyone else is using and why did you go with that?
Old 06-29-2010, 09:57 PM   #2
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
I would say the Toyota product would be your best bet...they designed the vehicle etc.When I read my yaris manuel,it advised that...one could experience shifting differences/difficulties...this is not the exact wording!.If I had to pick a second,it would definetly be Amsoil.The reason I said Toyota initially is because you never know when a manufacturer is going to use some funky material in their designs...and just so happens,possibly,they put additives in their tranny fluid to keep that mechanism 'just right'.Be it motor oil or tranny fluid,change it regularly.Tranny's are,no doubt more complex than the engine they are attached too(generally speaking).
frog13 is offline   Reply With Quote
Old 06-29-2010, 11:47 PM   #3
bronsin
bronsin's Avatar
I think I heard the T auto tranny fluid is proprietary. No one makes the spec except T.
Old 06-30-2010, 01:41 AM   #4
matanfr
diaper change in a yaris
matanfr's Avatar
Drives: 2009 multimode hatchback 5dr
bumping the post..does the tranny fluid in the yaris has single viscosity grade? (afaik,it's 75w,correct me if i'm wrong). is it possible to use RP max gear 75w90?
"there is no secret to the balance..you just have to feel the waves.."
Heretics of dune.
matanfr is offline   Reply With Quote
Old 06-30-2010, 01:51 AM   #5
detroiter
detroiter's Avatar
im talking about auto tranny just to put it out there...
Old 06-30-2010, 02:10 AM   #6
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Oops, sorry, my fault for misreading the thread :P I'll delete my previous post.
ENEOS also makes auto tranny fluid too now. Check them out - http://www.eneos.us/product/6
Old 06-30-2010, 08:25 AM   #7
127.0.0.1
Toyota OEM.
why ? because the hardware and software running the transmission were designed
and built to use it.
Old 06-30-2010, 08:34 AM   #8
firebob
Drives: 09 yaris
Without knowing how a different brand would affect paper and adhesive combo I would stay with OEM fluid. Using a different fluid could give more or less slip on the clutch packs. To much slip would wear out the paper faster and a lack of slip would shock load stuff that’s not made for it.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 06-30-2010, 11:00 AM   #9
ddongbap
Originally Posted by 127.0.0.1 View Post
Toyota OEM.
HAHAH! Hardware and software. Cause Trannys are hardware and the fluid is software. LOL!!!!!!!!
Old 06-30-2010, 11:03 AM   #10
127.0.0.1
automatic
the tranny and solenoids are hardware
and the ecu is software and programming.
manual transmission not included
Old 06-30-2010, 02:41 PM   #11
ddongbap
automatic
Oh, that makes 100% sense, so it is no longer funny.
Old 07-02-2010, 06:07 PM   #12
frog13
Tw200--excellent!
Matanfr...........inquire to your Toyota dealer, or read the container/manuel.
