Old 11-13-2009, 09:41 PM   #1
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
How to choose and install HID on FOG light
hi guys...
i found one HID kits on ebay and they looks cheap...
are they good stuff to go with??
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
just wondering does it fit my Hatchback 2008 (fog light)?
for what i know our fog light runs on H11 55W, that's what i know about it.
for HID, is that as long as is H11 and 55W will fit our fog light??
and yet is there any tutorial showing how to install HID kits?
URGENT helps needed, thx thx thx......
charleschia1986 is offline   Reply With Quote
Old 11-13-2009, 09:49 PM   #2
charleschia1986
all three pictures are given by the seller
Old 11-13-2009, 10:50 PM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Bulb fitting needs to be H11
if using the original and after market bolt in fog lights
Old 11-13-2009, 10:59 PM   #4
spookz
JDM yO!
Drives: '09 3dr. 5-spd
I know of people who have used that brand of HID and it is fine. However, if you're going to get them, please get the 35W version and not the 50-55W versions.. other drivers on the road are going to hate you for getting the 50-55W versions..
A 35W HID kit is already heaps blinding and brighter than a normal halogen setup. If you get a 50-55W kit, then you're going to be throwing so much light out that it's going to fly in all directions and blind other people. :)
Old 11-13-2009, 11:28 PM   #5
charleschia1986
thx for the replies....
just wondering is tat possible to install by myself? do u guys hav any tutorial for that?
what temperature rating should i use? cz BLUE beam light is illegal in Australia.
so i am planning to get a white light which give a little bit blue light.
8000K sounds good or lower? and if i lower the temperature, does it means it will lower the brightness?
regards.
Old 11-13-2009, 11:32 PM   #6
charleschia1986
i think in my case should be alright? because i m going to install the HID into my Fog light... it won't goes to high in this case right?
oh yea, one more Q. should i upgrade my headlight to HID or my fog light? cz i just replace my headlight into a 7000K bulb (not HID) few months ago which give me white with slightly blue beam light. so i am thinking of upgrading my fog light instead of my headlight since i already replace it into a 7000K bulb.
what do u think?
thanks...
Old 11-14-2009, 10:25 PM   #7
spookz
JDM yO!
If you're after a white beam with a blue tinge I would go for a 6000K kit. 8000K is blue.
And 55W HID in foglight is still not a good idea.. there is too much light for that little fog lamp assembly, light will be flying in all directions. Go find a 35W H11 HID kit.. That's probably your best bet.
Old 11-14-2009, 10:36 PM   #8
charleschia1986
i got your point spookz....
and yet if it gets TOO bright, wondering will i get any attraction from the road police??
because i do not want to get trouble with them..
and do u know underbody neon light is legall in Australia or not?
Old 11-15-2009, 09:52 PM   #9
spookz
JDM yO!
No problems, if it's too bright you'll definitely get the unwanted attraction from the cops.
As far as I'm aware, underbody neon lights are "legal" as long as your car is stationary (i.e. a show car on display), and "illegal" otherwise (i.e. you're driving with them on). :)
Old 11-17-2009, 07:25 PM   #10
severous01
yes, pls stick with factory rating of 55w halogen or 35w hid.
also, just about any hid kit will be fine. you can look into a small ballast design, but they're all about the same. yes i know higher ends are using higher quality parts as i described in another post, but you're not gonna find hella or phillips on ebay for 50 bux. so, for that price get whatever brand and color temp you want.
yellow is a really good color for fog and rain, blue is good for nothing really, and white is good for driving. so, stick with 3500k or 5500k or close to it for peak 'performance'.
Old 11-17-2009, 10:17 PM   #11
WolfWings
WolfWings's Avatar
Hell, for fog lights I'd recommend going as low as 2500k if you can find the bulbs.
Old 11-23-2009, 12:52 AM   #12
toyota
SRacer
toyota's Avatar
Drives: Toyota Yaris 2007
Send a message via Yahoo to toyota
If you're not sure how
to do it for sure, or you
don't think that you can do it
for sure, go to your local
body shop, thety should be
able to help you.
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop."
- Dominic, Fast & Furious
Learn The Truth about Six Pack Fast!
toyota is offline   Reply With Quote
Old 11-23-2009, 03:22 PM   #13
RSboyz
RSboyz's Avatar
Drives: 2007 Yaris RS
do we need to disable the day time running light if we installing HID in our head light?
RSboyz is offline   Reply With Quote
Old 07-05-2010, 10:16 AM   #14
kimrald
Drives: crv
regards.
I hope this would help you. I know one great site, they even have installation guides and videos. And everything about HID kits and HID bulbs are there. Here's the site http://www.blindinghid.com/toyota-hid-kits/ .They got everything you need to know. They also have lots of good stuff when it comes to HID Conversion Kits. Try to check it out.
kimrald is offline   Reply With Quote
Old 07-08-2010, 05:50 PM   #15
joeljcruz86
Little Eggy
joeljcruz86's Avatar
Drives: Toyota Yaris Liftback 3DR 2009
Send a message via AIM to joeljcruz86
I have a problem with my HID's. For the first 2 months since i've had them, they were working fine until now. They only come on when i have a normal headlight bulb plugged into the leftover/passenger side harness. I don't know why this is happening. I was thinking of using a wire with a 10k ohm 1/4watt resistor in the middle to plug into the to top hole on one end and the other to the right hole of the left over harness. This method i found on one of the forums is for to get the high beam light to show in the guage cluster. I'm hoping that this method would substitute the "normal headlight bulb" to get the HID's to be working as well.
If anybody has any solution and knows for a fact that any of the methods is not going to work, PLEASE LET ME KNOW!! THANK YOU.
joeljcruz86 is offline   Reply With Quote
Old 12-15-2010, 10:28 PM   #16
omcf
Drives: Yaris S
I wonder which has the Yaris Sedan HID on top and the fog light!!!!!
Please help mee
omcf is offline   Reply With Quote
Old 12-15-2010, 11:47 PM   #17
3000k JDM yellow, 6000k pure white, and 8000k with a tinge of blue. 10000k is very blue.
Color values are NOT THE SAME between companies! And neither is bulb or ballast quality!
(and neither is customer service)
Old 12-17-2010, 11:34 AM   #18
yaris0985
Drives: yaris sedan 09
for the headlight you need to buy a relay because you have DRL (day runing light)
for the fog nothing special...
take a look of my car 4300k headlight and 6000k and the fog light
http://yaris0985.monchar.com/
yaris0985 is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
