Old 09-13-2010, 07:12 AM   #1
1stOne
Drives: 2010 Sedan - Automatic - White
Question Single Tire Replacement - Using Pressure Sensor?
Road debris destroyed one of my OEM Bridgestones. (less than 10k on tires)
Is there a tire pressure sensor in the tire itself, as well as one on the stem?
And can they all be used (and easily removed/reinstalled) with the new replacement tire? I'm more than 2 hours from the nearest Toyota dealer so I plan on using a local shop after receiving my replacement tire from Tire Rack.
Thanks in advance.
1stOne is offline   Reply With Quote
Old 09-13-2010, 07:58 AM   #2
The sensor is part of the valve stem, so you should be OK.
Old 09-13-2010, 08:05 AM   #3
1stOne
Thank you very much.
Old 09-13-2010, 10:25 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Just make sure the tire place doesn't F-UP the sensor when they're dismounting the tire. Make sure to let them know its there.
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
recurring loss of tire pressure toad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2009 04:54 PM
Tire pressure sensors ztlonewolf DIY / Maintenance / Service 14 04-25-2009 05:19 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
