Old 04-15-2009, 04:17 PM   #1
auto pal
Drives: 2008 toyota vios 1.5G A/T
interior lighting
i'd like to install LED lighting in the area under the dashboard. where do i tap the DC power for the lights so that they go on and off
when the doors are opened and closed?
thanks for any information you can share.
auto pal is offline   Reply With Quote
Old 04-15-2009, 04:59 PM   #2
Liu997
Drives: 2008 Red Yaris LB
Yea I would also like to do this on my yaris. It would be nice to also have a switch for all of this.
Liu997 is offline   Reply With Quote
Old 04-15-2009, 06:12 PM   #3
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
you can check this out for the wiring on the dome light and tap into that somewhere:
http://www.etimago.com/yaris/repairmanual/EWD.pdf
...what i did is, instead of tapping into the dome light, i have two systems: one turns on when the lights are on. for that, i used the wire that would have normally been for the automatic shifter light (i have a stick) for those. they light up the little cubby area under the climate control console. the other lights i have light up the foot areas in the front and the cup holders in the back, giving an all around illuminescence. those are switched and powered by a 12v constant in the fuse box behind the driver's side sunglass holder (see the pic, courtesy of CTScott. the red wire toward the bottom is where it should go. there are two terminals. the top one is the 12 volt constant).
hope this helps someone!
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 04-15-2009, 09:00 PM   #4
auto pal
thanks for the information, enobmort42.
Old 04-15-2009, 09:35 PM   #5
Creeper
Creeper's Avatar
Drives: Silver 2DLB Yaris
Send a message via AIM to Creeper
i have my entire cabin light up, floorboards, airvents, compartments, under seats, under back seat, back floorboard. ill try and get some pictures if i can get my cam to take some decent ones. as for wireing i just wired from the batter with a inline fuse to a switch and then just wired the lights to the switch i have 3 switches in total inside outside and wheelwells. once you get the power in the cabin situated its easy as easy spread butter from there.
also have custom led lights in the glove boxes :)
Creeper is offline   Reply With Quote
Old 04-15-2009, 09:39 PM   #6
Liu997
Would like to see pictures.
Old 04-15-2009, 09:40 PM   #7
Creeper
Creeper's Avatar
it glows like a red hot moon inside :)
Old 04-15-2009, 09:41 PM   #8
Creeper
Creeper's Avatar
allthrough mine are all on switches and as to having them come on wehn the door opens i think enobmort42 has the right idea
Old 04-15-2009, 10:13 PM   #9
Creeper
Creeper's Avatar
sorry for the short notice, low res, shacky, camera pictures. Ill try and get the real camera out sometime soon
the bright light reflection in the center vent on the 2nd picture is just my air-freshienr not the bulb
Old 04-15-2009, 11:41 PM   #10
enobmort42
First time DIYer
enobmort42's Avatar
wow, that's a lot of red! mine glows a nice blue... at least the lady in the wendy's drive thru window likes it...
Old 04-16-2009, 12:35 AM   #11
Creeper
Creeper's Avatar
yeah forgot to turn on the car but climate knobs and shifter are red as well. taco bell lady likes mine :)
Old 04-16-2009, 11:37 AM   #12
Liu997
thats nice, that prob what I want to do. Undecided with the color lol
Old 04-16-2009, 03:09 PM   #13
auto pal
hi, creeper.
thanks for the photos. that's really red hot!
Old 07-24-2010, 06:39 AM   #14
Pwr_Dori
13 yr car freak
Pwr_Dori's Avatar
Drives: 09 toyota yaris Yrs
the only thing that i light that i changed was the dome light to a 16 red led lol and im only thirteen
Pwr_Dori is offline   Reply With Quote
Old 07-27-2010, 11:54 AM   #15
husaynkhan
Drives: new vitz
i also want to know where to plus the cable for the LED to light on when the doors open
husaynkhan is offline   Reply With Quote
Old 07-27-2010, 12:41 PM   #16
Here you go:
http://www.yarisworld.com/forums/sho...0&postcount=14
Old 08-01-2010, 06:26 AM   #17
husaynkhan
Drives: new vitz
thanks scott
