![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
Compress existing springs?
Yes, I am "mechaniclueless"...
But have always been bothered by how "high" and "bouncy" my 2008 stock Yaris rides and recently inquired about buying and installing lowering or sport springs. Seems I read something about "compressing" springs, though... Is this possible and, if so, is it recommended? Thanks; d'oh... |
There are coil clamps that you can buy that will draw two coils closer together. They can pull them to the point where they touch, effectively completely eliminating one coil. Don't know how well they work, but they are cheap to buy and could be a good experiment.
You can google 'coil clamps' and get some initial education on the matter.
![]() ![]() ![]() Drives: '12 Yaris LE Lagoon Blue Mica Join Date: Feb 2012
Heat them with a torch,or you can do it the right way and purchase lowering springs...
I purchased the springs tonight and installed them(2in.drop)... |
I wondered about just cutting a ring out of the existing springs to achieve the drop.
it won't help the bounciness. the spring rate won't change. if you want it stiffer, you need stiffer springs (with a higher spring rate). mine are progressive meaning the more they are compressed, the stiffer they are. gives a soft feel at first but then stiff in corners (or speed bumps unfortunately) |
#5 | |
やりすぎだ~
It's also possible to heat the coil springs up until they come close to each other. It's also possible to cut one coil off. but NONE of these are recommended. What's recommended? Buying a set of lowering springs that's made for your car. You can buy them new or look in the [For Sale] section for used ones. In fact, there's a member right now selling a set of used lowering springs. |
#6 | |
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
By modifying the original springs, you have change the specs of it - (e.g. spring rate / sprung/ unsprung weight) That in return changes the way the car handles and that can be very dangerous in high speed cornors or even in emergency braking as the behaviour the car can become unpredictable. When it involves handling, braking or even tyres which are also the safety aspect of a vehicle.......Never take the shortcut or cheap way out. |
Do it the right way....
I've been penny-wise and pound-foolish before, and I probably will be again, but not when my life's at stake. Thanks, guys! Put in a "bid" to 1.5; hope he's not insulted.
やりすぎだ~
You should send him a PM, not post it up for all to see.
I'm insulted. |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
So much misinformation...
You CAN cut coils out of a spring without problem (I've done it myself back in the day). But there are so many variables, if you don't know what you are doing, you probably shouldn't. If you cut coils, it WILL raise the spring rate (make it stiffer). The number of coils is one factor that determines a spring's stiffness. You cannot heat coils (with the spring on the car) because you will destroy the temper and you will have NO control how low the car will drop. Those spring clamp thingys my be good for a temporary fitting (for checking clearances, looks, etc.) but there is no way I would leave them on permanently. If your car is "bouncy" (as in cycles more than 1 1/2 times), you probably have blown shocks. [Putting on old codgers' hat] Modders have it so easy nowadays. Back in the day, we never had the range of aftermarket coils, shocks, coilovers, bushings, RCAs, sway bars, custom tubular arms, etc. Springs: cut your own. Performance shocks: Koni (on-road) or Bilstein/KYB (offroad). Everything else: custom ($$$) |
#11 | |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
As Yarisgui said please PM for price discussion Do not go the cheap route when it comes to springs, this is your cars connection to the ground, you don't want it to be ghetto rigged. |
やりすぎだ~
what misinformation?
OP asked if it's possible and if it's recommended. @Beef - Do not cut the coils on a Yaris. If you do, the coils will not sit on the perches correctly. (Notice how the coils taper to a smaller diameter on the ends) |
#13 | ||||
If you're short on money, long on time, not looking for the perfect ultimate race car handling, AND you know what you are doing, there is nothing wrong with snipping a coil or two from the stock springs. |
#14 |
Form>Function
I prefer my car not to act like a jetski when I drive down the road ^^
#15 |
やりすぎだ~
possible versus recommended.
I've done all of them "back in the day" as well - Back when coils were straight coils, not tapered and when there were few aftermarket parts. Heating coils just for the lowered look, sacrificing ride, was the cheapest way to go. But the Yaris and many "newer" cars are different from old school. If you look at the Yaris coils they're not straight. I highly suggest you buy a set of aftermarket coils rather than cutting them. @otterhere - I agree with Yaristeve on getting new shocks as well. After you drive over a bump, do you get that floating feeling like you're on a magic carpet? |
#16 |
I had pointed out to the OP (in another thread) that drop springs could be had for ~$150. I was trying to think of something you could do that was actually cheaper. I have changed my springs and went with H+Rs. I honestly didn't look too closely at the springs I took off. I know guys have cut springs before.
#17 |
Okay, guys; trying to get estimates here... Now they want to know if the STRUTS have to be removed first... Yes, no? Over $300 if yes, PLUS the cost of the springs and shipping; don't think I'll bother for just over an inch of lowering! Around $100 if not...
#18 |
Form>Function
in the rear the struts do not need to be touched.
in the front yes, you will need to remove the struts, use a spring compressor to squeeze the springs together and unassemble the strut while the spring is compressed and remove the spring from the strut then place the new spring on the strut and reassemble. Reinstall and done. |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | California | 11 | 08-21-2010 01:49 PM |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | Performance Modifications | 1 | 08-09-2010 03:45 PM |
| Bump stop length for drop springs. | PetersRedYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 02-17-2010 08:37 AM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
