Old 07-30-2010, 06:01 PM   #1
bst82551
bst82551's Avatar
Drives: 2008 Flint Mica Yaris Sedan
My first noise
Hey guys. I finally drove my Yaris hard enough to produce some sort of unpleasant noise. It sounds like it's coming from the belt/pulley (passenger side) of the engine. It may even be inside of the engine itself (maybe loose valves or failing timing chain). I just thought I'd throw a video up of the noise to see if anyone recognizes it or could diagnose it by just a sound a brief description. Here is the video I've made of it:
http://www.youtube.com/watch?v=DDLQc7EFa7g
-Brian
Additional info:
* not throwing any codes (I checked with my scangauge)
* 75k miles, mainly highway miles
* automatic tranny
* I drive it pretty hard
* Only maintenance done has been oil changes, tires, and air filters
* Mods: groundwire kit, K&N air filter & modded intake box (drilled holes in it and removed silencer tube), rear sway bar
bst82551 is offline   Reply With Quote
Old 07-30-2010, 08:37 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
My guess is the water pump. I wish I could tell you what it was for sure, but it doesn't sound good.
My only piece of advice is to stop doing this -> * I drive it pretty hard
Old 07-30-2010, 10:49 PM   #3
bst82551
bst82551's Avatar
I want to agree with you on the water pump because it seems like a common issue for the Yaris and it's coming from that general area of the engine bay. However... shouldn't I see the engine running a little hot if it's the water pump? The scangauge has been showing pretty consistent temps between 181 and 186 since I bought the scangauge four months ago. Any input is appreciated.
Old 07-30-2010, 11:07 PM   #4
Billiam
Drives: '10 White Yaris 4D LB
Originally Posted by bst82551 View Post
...However... shouldn't I see the engine running a little hot if it's the water pump?...
As long as it's still pumping, the engine won't run hot....even if it's making noise.
If you want to enjoy your car, stay off of the internet.
Old 07-30-2010, 11:42 PM   #5
bst82551
bst82551's Avatar
Thanks. I'll hold off on driving it until I make the short trip to have it looked at and/or replaced.
Old 07-31-2010, 08:12 PM   #6
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Exactly!.
frog13 is offline   Reply With Quote
Old 08-01-2010, 09:59 PM   #7
birdman
Drives: '08 Blazing Blue Yaris LB
Thanks for the video. Hearing that noise might come in handy some day.
birdman is offline   Reply With Quote
Old 08-12-2010, 04:16 PM   #8
B-Rock21
B-Rock21's Avatar
Drives: 2008 Black 3DR LB
Not sure if you've solved your problem, but I had exactly the same noise coming from the same part of my engine bay. Took it into my dealer and they said it was the water pump. Got it replaced and picked it up an hour ago, and the sound is gone 8)
What counts is not necessarily the size of the dog in the fight; it's the size of the fight in the dog.
B-Rock21 is offline   Reply With Quote
Old 08-13-2010, 07:58 AM   #9
bst82551
bst82551's Avatar
I replaced the water pump and one of the noises went away, but another noise remains. My trusted mechanic says it's the bearings in the alternator (another $550-600 of repairs). It's strange that both of the noises started up during the same few weeks. Thanks for the help guys.
-Brian
Old 08-13-2010, 09:05 AM   #10
hatchbackkid82
Drives: .
The bearings on my alternator just started to go, try to find a used one on ebay the for $50-$180
-Brian
engine noise 75k
Clicking noise when jerking steering wheel side to side/hit bumps left side eii DIY / Maintenance / Service 8 03-22-2010 06:46 PM
Very loud noise from the engine Stiv DIY / Maintenance / Service 27 10-27-2009 10:09 AM
Random tire thumping noise Tonavi DIY / Maintenance / Service 6 06-06-2009 02:27 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
