Old 08-23-2010, 12:15 AM   #1
auxmike
auxmike's Avatar
Cleaning plate on throttle body;can it be done?
Has anyone here pulled off their throttle body to spray down the throttle plate to remove all the black junk inside it?
Can this be done on a drive by wire like the Yaris has?
Old 08-23-2010, 12:25 AM   #2
detroiter
detroiter's Avatar
I'm not sure but what I can tell you is I cleaned it out before this way...Since it's electronically controlled and theirs no actual throttle cable, you need to turn the key to the power on position and have someone push the gas pedal and release it, so that way it opens the butterfly and shuts it. In my case, I didn't have anyone so I put omething heavy on the pedal to keep it held open.
Now it did flash a quick cel for a min or two after I started the car back up and took a few cranks to fire up, due to alot of the throttle/intake cleaner settling at the bottom of the intake but it just get's burned off, etc and the cel wil go away in a min or two, running well too without hesitation. I can tell you forsure that it was pretty black and filthy in that valve opening area in the throttle body area.
Old 08-23-2010, 12:28 AM   #3
Focus_Sh1ft
Focus_Sh1ft's Avatar
I'm almost positive the plate will come right off, it appears to only be attached by two small screws.
Old 08-23-2010, 06:54 AM   #4
auxmike
auxmike's Avatar
I'd like to remove the whole unit and spray it clean.
I know antifreeze runs through the throttle body and am also wondering if pulling it off the engine without disconnecting the hoses will prevent leakage.
I would remove the one on my Saturn about every 20k and it would be loaded with black gunk that would cause rough idle at times....
Old 08-23-2010, 10:16 AM   #5
Focus_Sh1ft
No problem, it's held on by like 3 10mm bolts and 1 nut. As long as the engine is cold you can remove the coolant lines that run to the TB without leaking anything.
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 12:12 PM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 04:36 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
