Old 08-22-2010, 06:50 PM   #1
PhotoDu.de
PhotoDu.de's Avatar
Drives: Yaris, duh
Hard Drive Magnet on Oil Filter
I have some extra hard drive magnets and was thinking of putting them on the oil filter to trap super small metal bits. The Yaris has an aluminum engine (maybe I'm wrong) so is it even worth the effort? It's a 3 day old car and have free maintenance for 2 years. Is the dealer going to care about the magnet at all?
PhotoDu.de is offline   Reply With Quote
Old 08-22-2010, 07:39 PM   #2
Klink10
Klink10's Avatar
Been running a FilterMag on mine since new. Had it so I put it on. As far as dealer, if you let them do the changes it's one more obstacle in the way. Besides that I don't see any issue other than making sure they put it back on the new one.
Old 08-22-2010, 09:30 PM   #3
severous01
ya, you can also get a heat extractor with a screw on clamp. it's basically an aluminum strip that's about 2" wide and has raised fins on it...and a screw clamp. it's supposed to draw heat from the oil.
magnets have been used since the dawn of the engine and oil....it's usually in the bottom of the oil pan.
Old 08-22-2010, 09:43 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
Ive always used those Neodymium strong earth magnets on the bottom of my oil filter on every car ived owned. Then just swap it to the new filter when i change it. Also i use a magnetic drain plug. Every time i change my oil there is always a bit of metal mush that i clean off. Using a magnet will extend the life of your oil pump.
Old 08-23-2010, 05:52 AM   #5
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up HDD magnets on filter and oilpan
I did the same on my yaris sedan. I have used HDD magnets(2ea) on filters. Planning also to put 2ea HDD magnets inside the oilpan via metal epoxy or welding.
ricepower is offline   Reply With Quote
Old 08-25-2010, 01:43 AM   #6
birdman
Drives: '08 Blazing Blue Yaris LB
Is there a good magnetic oil drain plug?
birdman is offline   Reply With Quote
Old 08-25-2010, 02:05 PM   #7
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Hard drive magnets on the side of the oil filter works great. No warranty issues at all.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 08-25-2010, 08:34 PM   #8
Astroman
Modded Moderator
Astroman's Avatar
I found some nice curved ones out of a old old old server, made a nice ring completly around the filter. I'll cut it apart when I'm due for my next oil change (I'm just past halfway on my 10k interval)
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Oil filter study sbergman27 General Yaris / Vitz Discussion 6 03-28-2010 11:30 PM
Oil Filter N2scouting DIY / Maintenance / Service 32 08-18-2009 04:40 PM
Add another hard drive to a laptop? CompanyXPaladin Off-topic / Other Cars / Everything else Discussions 4 11-23-2008 12:18 PM
external hard drive questions Shroomster Off-topic / Other Cars / Everything else Discussions 10 11-23-2008 04:46 AM
