Old 07-12-2007, 04:20 PM   #1
dallas
Drives: Yaris Hatch /Landrover D2
Sqweek while shifting (MANUAL)
Anyone have this problem? my transmission or linkage seems to make a sqweek when shifting from 3 to 4th. I thought it was suspension at first.
Drive your Yaris with the windows down and see it if sqweeks from 3rd to 4th shift. Im going to the dealer to check it out will keep you posted.
dallas is offline   Reply With Quote
Old 07-12-2007, 09:20 PM   #2
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
had this problem.. buy some jigaloo .. something like this to lubrificate :p it will stop after lol
OxyG3nE is offline   Reply With Quote
Old 07-13-2007, 01:40 PM   #3
dallas
Thanks ,so what did you spray the linkage and where?
Old 07-13-2007, 04:14 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
same problem here...
i had this squeeking on my echo from 1st to 2nd.. now it happens on my yaris from 3rd to 4th. doesn't bother me though :P
Old 07-13-2007, 06:56 PM   #5
Pars
Drives: 07 Yaris Liftback
I'm also having the same problems. If happens when I move the shifter. Even with the car off and my foot off the clutch, I still get the squeaking when I giggle the shifter (specifically toward 1st and 2nd gear...there's another linkage that seems to come into play when shifting toward 4th/5th that probably doesn't need greasing).
I took the the rubber boot off (comes of easily, just un-screw the shift nob and pull it out). There's some piston like linkage in their that seems to need some grease. Haven't greased it up yet, but will give it a try this weekend and have an update.
Pars is offline   Reply With Quote
Old 07-13-2007, 07:10 PM   #6
OxyG3nE
the problem is under the hood ..
Old 07-13-2007, 07:12 PM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Hey same here it keeps squeeking and squaking when ever i shift to any gear..im not sure if its my rubber ducky shifter upgrade..hmmm lolzz....
Old 07-15-2007, 12:51 AM   #8
dallas
Found the solution: get some chain and cable lube, and spray the linkages from under the hood. Have someone shift for you (engine off, clutch depressed) while you look in the engine bay to see the linkage points. No more sweeks!
Old 04-13-2009, 11:49 AM   #9
Shadowbeast
Drives: Yaris Hatch
Squeak When Shifting
This only occurs when shifting from 1-2, downshifting from 3-2, and 2-1. Is there an "easy access" area that I can place some grease to stop this annoying squeak? I'm not too sure where it is coming from but I can hear it when the window is down or up.
Any suggestions?
Shadowbeast is offline   Reply With Quote
Old 04-13-2009, 12:45 PM   #10
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
I had that problem a while ago. My car was under warranty at the time, so I just brought it in. They greased it a few times, but it would only come back a week or so later. About my 5th trip to the 'ship, they replaced some part (which took 2 1/2 months for it to "come in") and greased it, but it hasn't squeaked since... if you want, I'll check the invoice to see what it is that they replaced.
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 04-14-2009, 12:23 AM   #11
dallas
I'm interested too, if I grease the linkage it stops for a few days then comes back!
Old 04-14-2009, 12:57 AM   #12
CompanyXPaladin
Drives: 08 Yaris 5-speed
I'm interested as well - same problem. IDK if it's related, but my clutch has started squeaking when the pedal is depressed sometimes..
CompanyXPaladin is offline   Reply With Quote
Old 04-14-2009, 01:29 PM   #13
Syroyizhka
Syroyizhka's Avatar
Drives: 2007 Yaris Hatchback
I put Brake Disk grease on all of the joints under the hood, and after 10 mins of driving, nothing sqeaked for almost 2 months *(knock on wood)*.
Syroyizhka is offline   Reply With Quote
Old 04-14-2009, 04:33 PM   #14
IllusionX
that's the clutch bearing; it needs to be replaced.
Old 04-16-2009, 12:38 PM   #15
enobmort42
First time DIYer
enobmort42's Avatar
well, i looked at my invoice and they replaced the lever assembly, part number 33530-52110, as well as greased it all up. it hasn't squeaked since (almost a year). then again, that dealership hasn't always been honest with me in the past...
Old 04-19-2009, 11:41 PM   #16
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
I shot some WD-40 on the shift linkage under the hood..took care of the problem.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 04-21-2009, 12:26 AM   #17
dallas
Thanks for the part#
Old 07-23-2009, 07:31 PM   #18
BUT3RFLY_YARIS
Drives: Yaris S Sedan
HELP!!!! My clutch is squeaky...
When i shift from first to second it squeaks but when i shift from other gears it is fine... also when i check that it is in nutral it squaks too.... what can it be?? my clutch is responding good so i don't think i need a new one.
What is it???
Gonna live today like it's my last day!!!
BUT3RFLY_YARIS is offline   Reply With Quote
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 09:27 AM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
The Toyota Authorized Repair Manual. LoudYar General Yaris / Vitz Discussion 3 03-29-2007 12:20 AM
Finally drove the manual! drdavidr4u General Yaris / Vitz Discussion 2 06-14-2006 08:32 PM
