Old 09-13-2010, 01:18 AM   #1
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Spray painting hubcaps
Hi, everyone. I'm interested in painting my hubcaps all black except the toyota emblem I like it silver, how would I go abouts doing this.
Reccommended paints? Is there simple ones I can get at Walmart or Canadian tire that won't look like shit, yet work.
ex; aslong as it's black glossy water resistant and dirt it should be fine?
Looked for some guides didn't find anything along these lines links would be cool.
Thanks again guys.
Old 09-13-2010, 01:26 AM   #2
Brian
Brian's Avatar
Scuff sand, adhesion promoter, primer, base coat clear coat, wet sand if required. I usually use SEM paint.
Old 09-13-2010, 02:27 AM   #3
Freedan
Drives: 2010 Yaris Bayou Blue 3DR Lift
Kevin, have you heard/seen those "Beautification Trims"? I think that's what they are called. Basicly, they are trim for your Steelies. Looks pretty good and are about $40ish for a set of 4.
Here is a link to the thread that has pics of the "beautification trims".
http://www.yarisworld.com/forums/sho...hub+cap&page=2
All I can say is that they do look pretty good, especially if you clean and wax your steelies.
Freedan is offline   Reply With Quote
Old 09-13-2010, 04:13 AM   #4
padre1964
padre1964's Avatar
Drives: I'm back !! 2012 Toyota Yaris
did mine this weekend. sanded, washed, sprayed with krylon gloss black, clear coated. shall see how long they hold up.
best mpg so far, 46.1 !! Still shooting for 50 !
padre1964 is offline   Reply With Quote
Old 09-13-2010, 05:11 AM   #5
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Where do you exactly get beauty rings? And how do you put them on, those look badass.
They would prob look nice with some bullet caps too.
Thanks for the info so far guys, btw I tried to take off my hub caps but it felt like they were gonna snap. Went to my spare wheel and the only tools I found were for the steelies.
Old 09-13-2010, 03:32 PM   #6
padre1964
padre1964's Avatar
these are the rings i bought off ebay. http://cgi.ebay.com/ebaymotors/15-St...item518bcac617
he has several more sets, ships fast and i am happy with how they look. they just snap right on. as for the standard hub caps, just give them a good tug and they will pop off.
Old 09-13-2010, 06:03 PM   #7
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Damn, nice rings. You're sure those will fit on my stock 2010 sedan? If so thanks for the find I'll buy some of those with my next pay cheque I think it comes with 4.
Old 09-13-2010, 07:30 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
if you do spray, heat the can in a pot of boiling water, it makes the paint go on super thick, without running
Old 09-14-2010, 12:42 AM   #9
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Wouldn't that explode a can of paint?
Old 09-14-2010, 03:36 AM   #10
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Sorry for the double post, I also wanted to add if there were any ebay links for some centre caps to go with the stainless steel rings
Old 09-14-2010, 04:33 AM   #11
padre1964
padre1964's Avatar
http://www.harborfreight.com/replace...cap-93833.html
they are a bit too small and require being bonded on to the rim. also had to trim off half the bottom to fit flush. sand blasted and clear coated prior to installing. should be easy enough to knock them off if i ever have a reason to.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Steelies or Hubcaps or ??? CtrlAltDefeat Cosmetic Modifications (Exterior/Interior) 50 10-24-2013 09:50 PM
golden spray painted hubcaps.. abdallah380 Photo-Video-Media Gallery 13 06-14-2009 10:40 PM
Wax spray yarisnewbie Wash, Wax, Detailing, Exterior Repairs 20 03-20-2009 04:45 PM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 08:47 AM
