Hooch Brewer-Shine Sipper
Question About New Tires
Although I am not ready to get new ones yet, I was wondering if 195/60/17 would fit/rub on my 17x7.5 rims?
Not familiar with that tyre size. Where did you come up with that?
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
215/50R17 is as big as I think you can go with out any major problems.... but I am with Kimona... I am not familiar with that tire size either
I think theyd fit, but I'd go a little larger.. IMO
http://www.youtube.com/user/ProjectYaris |
I saw someone else had 60mm sidewalls, and right now I have 40mm. I have 205/40/17 or something. I guess I should look, huh? I just wanted more sidewall the next time around.
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Is your ride too rough?
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats." xbgod - 9/23/2010 |
Not really, but I would just like more tire between the rim and the road myself. Okay, there's a 205/60 R17.5 that Bridgestone makes. Would that be too much? I guess I need 17-inch tires, not 17.5. I have no idea.
tires read...
205mm (wide)/ 40% (of tire width) 17in (rim size) So for example and 205/40 has a sidewall hight of of just 82mm. (205 x 40% [or 0.4] = 82) A 195/60 would have a sidewall hight of 117mm and would be WAY too big. 25.4mm = 1in 82mm = 3.23in. 3.23 + 17 (rim size) = 20.23in 117mm = 4.6in 4.6 + 17 = 21.6in. 21.6 - 20.23 = 1.37in. That's quite a bit taller and you more than likely rub. This concludes our math lesson for the day. |
Okay, thanks BlueVitz. So I would need a 50 profile tire then at the most?
Let me make this way easier. What is the largest tire I can use on a 17x7.5 rim? I'm afraid my tire n00bness is showing badly. :/
That works out to a 97.5mm or 4.04in sidewall.
so 20.84 - 20.23 = .61in taller. It might work. |
The tallest tyre you could install with stock suspension is 205/50/17... provided you have proper wheel offset.
やりすぎだ~
205/50/17 like kimona said.
just a note: tires that are meant for 17.5" dia. wheel should NOT be used on a 17" dia. wheel. |
#14 |
I thought the rims I got said 17 x 7.5, but I don't know. Offset was 40. Seems I don't know much.
#15 |
I'm just going to try to move up to a 50 profile next go round. Thing is, my current tires are new so it will be awhile before I buy anyway.
#16 |
やりすぎだ~
my bad, I got it from your post #7.
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| Question about tires.. | white_rice | Canada | 10 | 04-15-2010 01:09 PM |
| 2007 Yaris bad tires | weaver615 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-27-2010 07:21 AM |
| OE wheels + tires question | Tonavi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 03-05-2009 10:35 PM |
| noob question about stock tires | xCookiE | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 06-19-2007 08:40 AM |
