Drives: 2007 Yaris Join Date: Oct 2010
Preliminary questions about engine conversion
I have been considering converting my car to a hydrogen system, not not some hokey ebay bullshit. but the problem is, they do not recommend using the system on an engine with a higher then 9.5 to 1 compression ratio. I have a 2007 Yaris, its all stock. So the engine has a 10.5 to 1 compression ratio. The issue is because hydrogen burns much faster then gas, which can cause predetonation at higher compression ratios. I am hoping that because the engine is aluminum instead of cast iron it may not have the issue as much? If not, any ideas as to what would be a good engine to swap it with that has a 9.5 to 1 ratio (or lower)?
Mr. 155 and climbing
wow...sounds like a hell of a project. I have no useful information for you, but I wanted to truly wish you best of luck...very cool.
Only Happy When it Rains
swapping the engine sounds like it would cost a ton. You could also look at getting lower compression internals. Rods and pistons I believe.
Colin Chapman disciple |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
You might be able to get a head spacer made to drop it enough, but I haven't seen anyone with one on a yaris, some of the boosted people might use one.
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Yeah the boosted guys would know more. Sounds like a neat project!
Swap CP 9.5:1 pistons into it.
you won't need aftermarket rods unless you're going to make MORE than stock power.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| noob here.. need help on questions about turbo and engine life | 10Kyaris | Forced Induction Forum | 43 | 10-06-2010 09:26 AM |
