![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Just curious...
I heard from a little birdy that fixed pulley sc are coming for the yaris, not the blitz.
Is it possible to use a boost controller to control a supercharger?
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats." xbgod - 9/23/2010 |
prop215.
Drives: Toyota Yaris LB Join Date: Sep 2010
im really not sure, but i dont think you use boost controllers on superchargers. its the size of the pulley that controls the boost. im not sure, but i think thats how it works.
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you could do a blow off valve, just like a turbo. they're actually teh same thing (cintrifugal any way) so, the pulley supplies the boost amount, but if you're over the amount you want you can BOV it just like a turbo
but it's easier to dial in SC pressure with pullies because it will always spin and produce pressure at the same amount at the same rpm at all times...not like turbo that depends on exhaust which always changed depending on load and rpm...as well as temps and all sorts of things any way, if you got too much boost BOV it. |
No. A waste gate controls boost, not a bov. I can run 8 psi and I can run 30 psi with the same bov and no changes to it.
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Yes you can control boost with a by pass valve. They are also called "pop off valves". All the new VW's have it. It works by bleeding boost @ a desired level. HKS has has this for years......
^. That's the same function as a waste gate on a turbo system, right?
Yes a wastegate controls boost & a by pass valve can also be used also to control boost. There are actually some drag racers here that have turbocharged cars with no W/G & only use the by pass valve to control boost.
Drives: "Burning It Down GTX2860RS XB" Join Date: Sep 2010
Yes thats right a waste gate, just like the one I put on the Blitz S/C with a custom pully.
I used a custom fit one from Magnuson. Aras |
| What age are people here? Curious what age group is buying this car. | JDE | General Yaris / Vitz Discussion | 351 | 05-19-2011 04:28 PM |
| I've NEVER been more curious to find out! | Syroyizhka | General Yaris / Vitz Discussion | 5 | 04-15-2009 07:35 AM |
| Curious about the Yaris | Second to none | New YARIS Purchase Forum | 1 | 12-01-2008 10:37 PM |
| Curious about GB | uncleyaris | Canada | 25 | 11-12-2008 06:32 PM |
| curious question | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 19 | 02-04-2007 01:46 PM |
