Old 10-28-2010, 12:55 PM   #1
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
how i mounted my lightweight battery
so my question is,"is this really safe?" Meaning could the engine bay get hot enough to ignite the box and paper stuff?
What I did was take the box the battery came in, added in the paper stuff the company used to make sure the battery didn't move, tape it all together with packing tape. It is very secure in the car, but i was just brought aware of how hot it can get in there. When I have money I plan on buying a real lightweight aluminum mount, but is it a good idea to leave it like this until then?
Colin Chapman disciple
Old 10-28-2010, 01:09 PM   #2
RedRide
RedRide's Avatar
I don't know about fires but, there has to be a better way to mount it.
A paper battery mount?
Old 10-28-2010, 03:11 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The burning point of paper is over 200°C. So unless it comes into direct contact with something that hot, it's not going to burst into flames.
Old 10-28-2010, 04:15 PM   #4
why?
why?'s Avatar
Drives: Yaris LB
It certainly isn't pretty, but it was what i had on hand. it is not an ideal solution, but it works for now.
The combustion point of paper is 451°, like the book. But temperatures can get hot in the engine bay, and i just wanted to make sure. It is not touching anything at all but the battery tray on the bottom. I highly doubt any track would let me on the way it currently is.
What is the normal temperature or the engine bay? I thought it was rather high?
Old 10-28-2010, 04:30 PM   #5
Bluevitz-rs
Well, it totally depends on ambient air temps, but generally about 30-50°F hotter than outside. So not really that hot on an average day.
Old 10-28-2010, 07:07 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I don't think you have anything to worry about. Dry leaves get in the engine bay during the fall. I've never seen one ignite even when in direct contact with the engine.
Old 10-28-2010, 07:22 PM   #7
Klink10
Klink10's Avatar
I would worry more about the paper becoming so water saturated (Rain/wash etc) that it would lose its strength if you want to say it has any. I assume that your hold down clamp is securely fastened. You found a way to do it, just not sure about the sturdiness of the whole affair.
Old 10-28-2010, 07:54 PM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
The glue in the tape will give in in no time... Which in turn will move the battery around, which in turn shake the battery tie down loose.
Something similar happened to me, although it was with an OEM-sized replacement battery. I suggest you get that fixed soon, since that battery tie down can end up in the engine bay and hit something important. .02
Old 10-28-2010, 11:09 PM   #9
Bluevitz-rs
It looks like you could fit a piece of 2 by 4 in the void. That would be a better long term solution.
Old 10-28-2010, 11:16 PM   #10
darkMINI
Drives: 08 hatch
U could use some marine lumber. It's made out of recycled plastic and comes in normal wood lumber sizes. Should withstand moisture pretty well.
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 10-28-2010, 11:20 PM   #11
Bluevitz-rs
even a regular 2x4 will never rot in the life span of the car under the hood. I'm just saying use that until you get the proper battery tie down. You could probably find a scrap piece for free at Home Depot.
Old 10-28-2010, 11:29 PM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You could even paint it a satin black or something...even spray bomb it so that it is less noticeable...
Old 10-29-2010, 12:28 AM   #13
why?
why?'s Avatar
Drives: Yaris LB
yea, it is something i am definitely going to monitor. I just wish the cables connected to the terminals weren't so inflexible.
Is it easy to get them to move and adjust? What would that take so I use a battery mount that lies the battery flat, or uses the other style of connectors?
I am still learning about batteries, battery boxes, and the like, I just wanted to be able to drive my car, it has been sitting for a couple of weeks.
And stopping by home depot is definitely on my list. Do they just give away scrap lumber? that would be nice. I have no idea how their lumber yard works.
Old 10-29-2010, 09:10 AM   #14
Klink10
Klink10's Avatar
Check any home construction site for scrap (time to dumpster dive). You can lay it flat however you would lose the stock hood prop retaining ability unless you just want it to dangle which with driving etc it could swing over and short out something or cause other type damage bouncing around. Do a google on battery relocations and see what others are doing as far as boxes and mountings. I spent probably 2 weeks researching the possibilities before doing what I ended up with.
Old 10-29-2010, 03:17 PM   #15
matthewai
matthewai's Avatar
Drives: it is kinda stock
that is prettttyy bootleg
Old 10-29-2010, 05:27 PM   #16
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
LOL ^
I need something like that for my sound sistem i think i would put it in the trunk tho
Originally Posted by sw07gt
Old 10-29-2010, 05:35 PM   #17
why?
why?'s Avatar
Drives: Yaris LB
yea i've been looking. I actually was able to order a mount today, one of the braille mounts, for a good price.
Then I'll see what of that other battery stuff can come apart, and where i can safely and securely mount the battery.
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Installation of a Battery Isolator frostbitten In Car Entertainment + Electronics (audio / video / alarm) 3 10-07-2009 12:11 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Lightweight battery install Klink10 DIY / Maintenance / Service 11 02-28-2009 08:43 PM
