Old 10-21-2016, 11:42 PM   #1
superduc
Drives: 2007 yaris sedan s
help...07 yaris starts but mostly doesnt work
i was planning on installing an alarm on my 07 yaris sedan. testing the 12v constant on the ignition but stupid me plugged the red wire on the mulitimeter on 10a max.i heard a short and checked everything after. power windows, cigarette lighter, reverse lights, climate control, power mirrors, turn signals, wipers, radio stopped working. checked the fuses for those and they are still good. lights turns on high beams too and parking lights. the car starts. power doors works. domelight works. brake lights works. HELP!! what could be wrong?
superduc is offline   Reply With Quote
Old 10-22-2016, 12:47 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Need someone with an EWD to post what the main fuses are.
Check the fuses under the hood. There's also some fuseable links on the batter + lead I think.
Old 10-22-2016, 01:02 AM   #3
superduc
if it's fusible link. the car would still start? btw the power steering doesnt work too. sorry to ask but what's ewd?
Old 10-22-2016, 07:35 AM   #4
Yes it will.
Old 10-22-2016, 08:53 AM   #5
superduc
I've checked the fusible link.look at the 60a and 120a fuses and they look like they're still intact. one thing i worry about is...could it be the ecu itself? i was testing the 12v yellow constant from the ignition and then i heard a pop or short circuit while im in there. when started the abs and p/s lights stays on.
Old 10-22-2016, 09:12 AM   #6
superduc
is there a main relay for all those I mentioned ? thanks in advance guys.please be patient with my questions
Old 10-22-2016, 09:55 AM   #7
Bluevitz-rs
Electrical Wiring Diagram.
Did you test the fuses with a volt meter?
Old 10-22-2016, 05:05 PM   #8
superduc
found the culprit. it was the am1 fuse inside the car. 25 amp.
Old 10-22-2016, 05:13 PM   #9
Bluevitz-rs
Old 10-22-2016, 05:24 PM   #10
Much better than blowing a fusible link.
Old 10-23-2016, 01:29 AM   #11
superduc
was beginning to think it was the ecu
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
one rear brake light don`t work yaris 2008 abou salou Canada 1 04-03-2012 01:38 PM
xd springs work on yaris? toad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 11-03-2011 02:07 PM
Anyone in So Cal needs work on their Yaris Bdaslug California 24 08-26-2007 06:10 AM
