![]() Drives: 2006 Toyota Yaris YRX Join Date: Apr 2011
New Sound System
I plan to purchase a new sound system for the car. Right now it's just the stock speakers and head unit.
Before I went ahead and bought anything, I thought I would post here to get some opinions on the speakers/sub etc. So let me know what you think. Speakers Front http://www.fusionelectronics.com/car...speaker-system Speakers Rear http://www.fusionelectronics.com/car...2-way-speakers Sub http://www.fusionelectronics.com/car...edge-enclosure I haven't been able to find a head unit for the car that'll fit. And I don't want to buy something on the change that it wont fit. So if anyone knows some good head units out there that fit my 06 Yaris let me know. And let me know what you think of the set up. |
Roadrunner Jr.
Why Fuzion?
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
Well, I have never really put a new sound system in any of my cars before. I have a couple mates who use it, so I just assumed it was a brand that people used. Maybe I should go with something like Clarion, Pioneer, Alpine etc?
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
I really like my Polk Audio components. But depending on your budget, SQ has some Ideas on good stuff too for sure!
I don't have a minimum/maximum budget at all. So I'm open for suggestions for some great sound systems.
#6 | |
![]() ![]() Drives: 2007 Join Date: Dec 2010
and just about EVERY head unit could be made to fit the yaris. always do a quick search of the forums. theres a stickied thread showcasing everyones aftermarket head units - as well as countless other post of peoples experiences with head units. first we would need to know what would you want out of the head unit - as well as your speaker set up. we could just tell you some of the best subs and speakers available and you could spend $3000 on the setup.... |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
I would be thinking lightweight with clean sounds...I don't see a yaris lugging around a couple hundred pounds of stereo equipment as a benefit.
Upgrade the head unit to an indash TV, replace the stock speakers(maybe run an amp to them,but it's not necessary) and add a small sub(10" should do nicely). Edited:quote deleted, not sure how I quoted that other user....
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg Last edited by mazilla; 05-01-2011 at 05:40 PM. Reason: quoted on accident |
#8 | |
Roadrunner Jr.
That's why I posted that...didn't know I had to justify. ![]() My reasoning for suggesting an active network is because...well...it's better. You have a huge range of flexibility versus passives. You can change anything at any time...settings, speakers, amplifiers, source units...and not have to re work the passive network. That being said, passives are a thing of beauty.
I ain't even mad
Import subs, I got a flex 10' UK set up that pounds hard.
Roadrunner Jr.
You could go all out with these:
![]() ![]() You'd talk with Marc Rushton in Sunbury, Victoria... ![]() ![]() If I was putting together a two way pure SQ system, this is probably what I'd come up with. I'm there already with the speakers and processing.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 05-01-2011 at 05:40 PM. |
Roadrunner Jr.
Depending how we define it? Sure. Active crossovers are generally more expensive.
I'd throw this at you though... Can you go from a butterworth or linkwitz up to a 48dB slope on any of your speakers on any of 6 bands used? Oh that includes full range, low pass, band pass, or high pass on any of those bands, phase control. I can't stop there, how about 1/3rd octave control on ALL speakers used, time alignment, output control, optical/tosslink input and output...all in one 6"x8" chassis that is controlled at my fingertips. I can change any of these settings within two minutes if not quicker. The 112dB S/N doesn't hurt anything either. Now...tell me how a passive is better? It's much less flexible. It is however a unique snapshot into how one tunes his or her system.
Roadrunner Jr.
If one has a bad sound DUE to time alignment...that person needs to swallow the end of a revolver. It's WAAAAY too simple to solve. T/A and crossover slopes are directly connected.
I might understand if you said bad stage due to T/A. Otherwise, the person messing with T/A is a drooling knuckle dragger that can't spend a few hours to play with the settings. I can think of one "simple" thing that one could use a 48dB slope on...a low pass midrange taken to the extreme separated from the mid bass by several feet and played off axis. Now when you say time alignment are you talking the physical PLD's or the adjustments made on the signal?
Roadrunner Jr.
I don't know what to say without being offensive to the people you know that play with the signal for weeks and not being able to get a good sound. It's their limitation. A passive crossover system won't help a bad sound over an active system...The passive crossover is SO limited.
I completely concur with buying good equipment, you can use the passives and forget it. Hand me ANY car you're working with, the passives and an active processor and I can show your ears the difference. There's too much one is able to do NOT to be able to fix any "dead sound" issues with an active versus passive. In my instance, I've got great equipment, and world beating flexibility. I don't limit myself to one sound profile. I can and have changed the sound with a couple flips of the stereo knobs that have improved the stage and sound from the previous set. I'm not limited to the one setting that a passive confines one with. If we're simply placing a passive into the signal chain, I can easily (yes EASILY) recreate that exact same network with the active processor. T/A would really have nothing to do with it unless your speakers are already a little off due to whatever reason. The passive crossover won't magically fix bad sound. That's why T/A there...to adjust for odd or tweaky placements. If you have dead sound due to time alignment, reset it and do it over because you've screwed something up. It's be folly to throw away more flexibility away simply because one is too thick-headed to figure it out. For me it's like going from flying a modern airplane back to a WW I airplane.
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 03:11 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
