Old 12-28-2010, 11:41 PM   #1
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
lug nuts
will i need new lugnuts if i get aftr market wheels?
"who the cap fit let them wear it"
20104dr is offline   Reply With Quote
Old 12-29-2010, 11:28 AM   #2
Yaristeve
Drives: 3-door hatch
Depends on the wheels you have and the wheels you're going to get. Standard lugs for the steelies are the acorn 60degree taper lugs. Most wheels now use this style lug nut.
However: Some wheels have a shank style lug. Some Toyota wheels use a larger diameter shank lug. Some VW wheels use a hemispherical bolt or lug.
Old 12-29-2010, 11:44 AM   #3
33OH
Drives: '08 Yaris
Most likely (but not always), yes. If the opening is narrower you will need "tuner" lugs. Our car uses the 12x1.5 size.
Old 12-29-2010, 01:31 PM   #4
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
i am going from the steelies to xxr. i figured i jus get new ones anyway, thanks yaristeve/330h
Old 12-29-2010, 04:01 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
be wary of the spline drive lug nuts. . those splinedrive keys are fragile and do not handle side loading well.
i've had a set of Kyokugens for 6 years now, and have yet to break my key. 7-sided lugs FTW!
Old 12-29-2010, 07:53 PM   #6
33OH
Drives: '08 Yaris
Yeah, the keys for spline drive nuts are weak. We have about 5 of them laying around here just in case any break.
Painting the lug nuts......is it possible? pspeezy DIY / Maintenance / Service 6 11-01-2010 02:50 PM
Blox Aluminum Lug Nuts advocate Performance Modifications 20 02-05-2010 02:55 PM
LUG NUTS elmo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 05-01-2009 06:31 AM
Cheap Lug Nuts? KwonSau Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-06-2007 12:51 AM
Lug Nuts for Konig Helium Wheels? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-19-2006 05:58 PM
