![]() Drives: yarius III Join Date: Apr 2016
toyota yaris 2013 key blade
What type of blade is required to copy a toyota yaris 2013 key? I tried to copy key with a toy47 blade bought on eBay but this copy work only for the driver door but don't works for the contact. I assume that the blade used does not match.
![]() Drives: lowered/ exhaust Join Date: Apr 2016
If your car has an immobilizer then you have to get it programmed by toyota
Sent from my iPhone using Tapatalk |
You don't understand. I can't rotate the copied key in the ignition switch. Copied key works only in the driver door. The original Toyota key work fine in ingnition switch and driver door.
Does anyone know what type of blank blade are used for Yaris 2.
Hold both keys together and see if their cut the same or juggle the key in the ignition cylinder. Sometimes if a key is cut just slightly differently it will work in one thing and not another
#6 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Also in a 2013 Yaris you will need a key with an immobilizer chip that needs to be programmed otherwise even if the key turns in the ignition it will not start the car. You don't have to go to a dealer but you're options for programming are a dealer, a professional locksmith, or somebody that has access to Techstream software (and the cable). |
| 2013 Black Toyota Yaris LE - 51000 odo | tyta4lfe | Cars for Sale by private party | 1 | 08-23-2016 10:41 PM |
| Toyota Yaris 2013 with Touch and Go | intercar | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-29-2015 07:51 AM |
| Recent Toyota Yaris recall " electric steering" | marcus | DIY / Maintenance / Service | 6 | 07-10-2013 02:30 PM |
