Old 08-24-2009, 04:46 PM   #1
RedRide
RedRide's Avatar
Removing plug on headlight bulb.....
Help....
I tried to remove the plugs on my headlight bulbs in an attempt to change them.
However, I could not remove them. Is there some sort of "release" that I'm missing or, do they normally need a bit of stern coaxing to remove them?
I have a pair of "PIAA Extreme White Plus" H4 bulbs begging to be installed.
Old 08-25-2009, 02:31 PM   #2
RedRide
RedRide's Avatar
Anyone?
Old 08-25-2009, 02:38 PM   #3
Brian
Brian's Avatar
They should just pull off
Old 08-25-2009, 05:11 PM   #4
RedRide
RedRide's Avatar
Yeah, that's what I thought.
They are reallyl stuck on there which is unusual for a new car.
Old 08-25-2009, 05:37 PM   #5
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
they are on there tight. to make it easy, pull the bumper off a little bit (take off the black push pin thingies on the top and the one on the wheel side), remove the headlight. takes like 5 minutes easy.
Check out my Build thread:
Old 08-26-2009, 05:30 AM   #6
coffiend
coffiend's Avatar
Drives: 08 Black LB
it was a frustrating pain in the ass for me too. removing the headlight is the easiest way to go.
Old 09-05-2009, 06:59 PM   #7
RedRide
RedRide's Avatar
Ok...... I finally got around to changing the bulbs.
&%@&*%^$## Toyota!
A large pair of needle nose pliers made easy work of pulling the plugs off.
It was all down hill from there.
It took me quite some time to secure the clips on the passengr side.
However, I found it imposible to secure the clips on the drivers side so, I wound up removing the headlight.
As least now after removing it, I now have a better understanding just how the clips are secured so maby next time I wont have to remove the headlight and curse out Toyota nearly as much.
Old 09-05-2009, 07:45 PM   #8
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Most people have to take the headlight off on the hatch to change out the bulbs
Old 12-22-2010, 12:45 AM   #9
Randy!
Drives: 07 Liftback
Here's how I did it
My driverside bulb went out. My car's about 3.5 years old, 70K miles. It was ridiculously difficult to makes this happen. Everything was WAY more snug than the manual and the various threads seemed to indicate.
It took a couple attempts, my left hand is a little scrapped up, so is my cousin's, but the bulb has been changed. The use for a second set of eyes was in step 4. Knowing how everything works now, I think then next one will be simple enough on my own. If this write-up is clear enough, you can manage it, too.
#1) I wiggled the hell out of the plug to loosen it. Try to pull as much as possible while wiggling.
#2) The electrical prongs on the bulb are pretty long, and it's hard to pull the plug straight back with so little room for your hand. I got the inboard side to come off a little bit by hand, but the outboard side wasn't moving much. I then used a long thin flathead screw driver to square up the outboard side. Get the screwdriver blade in place on a high point on the plastic plug. Tap very very gently a few times. Once the plug was square I went back to hand wiggling and it popped off.
#3) The rubber hood is cone-shaped. It was easy to get the outer part of the hood off the boss. It was impossible for me to remove the inner part from the bulb while the bulb was still in the headlight. Despite pulling ready really really hard, wiggling, prying, feeling from the inside and the outside, and starting to see if I could just remove the whole headlight, I ended up leaving the cone in place until the bulb was out and sitting on my workbench. This is the step where I give up the first time.
#4) I had some help for this next part. Once we decided to leave the rubber hood in place, my cousin worked on the bulb and I looked through the headlight at the visible part of the release spring. There are two semi-circular notches in the reflective headlight surface, one on either side of the bulb. The release spring is a U-shaped wire. As you squeeze it, the wire flattens and will slip past the tab holding it in place; this is visible to a second set of eyes.
Put on some gloves. You'll going to press very hard, and without room to position your fingers, it'll probably be a sensitive part making contact with the release spring. As he pinched the ends of the spring towards the center, I could see when the spring had deflected enough to release. When it was flat enough I said "go" and, while still squeezing, he pulled backwards. We did one spring at a time. The outboard spring came free pretty easily, the inboard one was tough. Working by yourself, it'll be tough to know when the spring is flat, that's why the glove is helpful, so you can squeeze really hard, hold it in place and try pulling, then squeeze a little harder, and try pulling again until the spring releases.
#5) I compressed the rubber hood in my hand, and wiggled and pulled until the hood/bulb assembly came free.
#6) With plenty of space on the workbench, I used a small screw driver to gradually work the inner part of rubber hood off the dead bulb. The inner surface is grooved and makes contact with about 15mm of the bulb, so it's no wonder there's so much friction holding it on.
#7) Still on the workbench, I slid the hood onto the back of the new bulb. A little WD-40 helped. Put the lube on the metal part of the bulb, not on the inner surface of the rubber hood. This way no lube ends up on the glass of the bulb. Stuff on the bulb glass apparently shortens the life substantially and as you've figured out, installing a new bulb is not that easy.
#8) Again with my cousin under the hood, I looked through the headlight to tell him when the new bulb was in straight and square. This would be simple enough by yourself, but it went really quick with an extra set of eyes. He pinched the springs and pushed them into position. This was easier then the removal, since he could just squeeze and push until the spring popped over the tab and locked.
Gloves are useful here, too. It's a pain to slide the bulb back in, and it'd be easy to accidentally smudge the glass with your oily skin.
#9) Turn the key, flip on the headlights, rejoice.
You may also feel such a sense of accomplishment that you'll consider calling up a dealership to tell them what to do with that $45 OEM bulb that they'll "install for free" because they won't touch the exact same bulb you bought retail for $12--claiming it might damage the electrical system--even though you're happy to pay for the 15 minutes of labor they'd need.
Randy! is offline   Reply With Quote
Old 12-28-2010, 07:52 PM   #10
charlene8301
Charlene
charlene8301's Avatar
Drives: '08 Yaris 2dr Hbck Auto
Send a message via Yahoo to charlene8301
Okay so I will admit I am a chick and don't know most of what guys are talkin about with cars but my guy bought me some bright blue headlights for Christmas and we discovered that the front bumper had to be removed to get the factory lights off and install the new bulbs.
charlene8301 is offline   Reply With Quote
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 09:58 AM
DIY for 09 S LB Headlight and Foglight Sylvania Bulb changeout? YarHole DIY / Maintenance / Service 4 05-09-2009 11:17 PM
2007 hatch - Headlight Bulb whiteghetto DIY / Maintenance / Service 8 02-09-2009 08:04 PM
Changing Headlight Bulb Tutorial RSboyz DIY / Maintenance / Service 29 03-15-2007 02:35 PM
How to remove headlight bulb with chubby hand? D: jmew0ng DIY / Maintenance / Service 2 02-22-2007 12:40 PM
