![]() Drives: 2007 Yaris S Join Date: May 2011
Yaris not starting after major engine repair
My daughter drove her 2007 Yaris hot (three times) and warped the head - Being an old shade tree mechanic I thought I would save her some money and do the job myself. I tore it down had the head resurfaced and reworked and put it all back together carefully, following the online yaris service manual step by step - Now I cannot get any fire to the ignition - It does NOT have the engine immobilzation system ( it was an option in 2007 in US) - I have checked the sensors (Crankcase, camshaft positioning sensors) and they fall within specs - I asked a local mechanic and he thought that my ECU needed reprogramming by the dealer - Is this possible? I can find no mention of it in the service manual online. What else could keep me from getting fire to the plugs? I checked the ECU fuses - all ok - checked the harness - all ok - the car was running (badly) when it tore it down - I'm at my wit's end. Any advice would be appreciated.
#2 | |
USAF_SrA_E-4
Are you getting electricity ?
The ECU definitely doesn't need reprogramming. Do you have an OBDII code reader that you can plug in to make sure that the ECM is actually alive?
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Might be silly but.. is the battery still alive?
yes to all
Thanks for the posts! I do have a reader and the ECU is alive - I am getting electricity to the places I am supposed to .... except the plugs - It spins like a tops but never hits - I took out the plugs and followed the service manual procedure for testing for fire to the plugs - no spark - these are new irridium plugs ($8 each!) I have gone so far as to take a volt/ohm meter and check the ecu and harness to make sure that the pins that go to the various parts of the ignition system are alive and they are.... I guess I am going to have to have it towed to a dealer. Thanks for the input!
Check the AM2 fuse in the under hood fuse panel.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Hmmmmmmmm .Timing off ?
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
How is the ignition triggered in our motors?
Could the cams be 180* out of phase with the crank/ignition? |
![]() ![]() Drives: 07 lb jeep tj Join Date: Oct 2010
scan for codes and go from there.
| Yaris vs MR2 Spyder | regal | Off-topic / Other Cars / Everything else Discussions | 36 | 01-25-2026 12:56 PM |
| '54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem | Lettuce | UK | 0 | 09-30-2010 06:21 AM |
