Old 01-29-2011, 03:46 AM   #1
Spahrticus
Spahrticus's Avatar
Drives: ///M3, Yaris
Quick headlight question.
In your guys (and gals) experiences, do the OEM headlights come apart easy so I can gain access in the chrome part for a lil DIY? Thanks in advance.
Spahrticus is offline   Reply With Quote
Old 01-29-2011, 08:56 AM   #2
Search 'projector retrofit'.
Most report separating the lens from the housing to be relatively easy.
Old 01-29-2011, 10:06 AM   #3
big lo
big lo's Avatar
Drives: 2007 VIOS
And yes they are easy to open, and as Wee yari mentioned threads on retrofit, good luck
Old 01-30-2011, 07:14 AM   #4
Spahrticus
Spahrticus's Avatar
Thanks for the replies guys. Don't have my Yaris yet, but wanted to get an idea of what I'm up against. Thanks again.
Old 01-30-2011, 04:21 PM   #5
jonismyname
Drives: 08 liftback 5spd
i did it with no heat and a screwdriver. fingers hurt an hour later, but i did it at work on a slow day...
worth it alone to acquire the ball of amazingly sticky stuff that OE used to glue them together. a bit no the end of a pen makes a very entertaining workplace weapon. i can stick one to a fellows back from 20ft...
jonismyname is offline   Reply With Quote
Old 01-30-2011, 04:32 PM   #6
big lo
big lo's Avatar
Drives: 2007 VIOS
How in did you open the headlight with no heat, no wonder your fingers are hurtin afterwards if you don't want to use a oven then a blow dryer will do just fine and they come apart real easy that way
Old 01-31-2011, 02:26 AM   #7
CAyaris
CAyaris's Avatar
Drives: 2008 Toyota Yaris Sedan
Send a message via MSN to CAyaris
Put in in your oven at the lowest temp for about ten minutes or untill u see it starting to spread than pop it out and pull it apart, as for putting it back together, put it in the oven just to heat it than push it back together
108hp and still rolling
CAyaris is offline   Reply With Quote
reverse gear..quick question.. Yaris2910 DIY / Maintenance / Service 10 01-11-2011 06:14 AM
Quick Oil Question nickhjort Performance Modifications 5 04-27-2010 09:51 AM
Quick question.. harveyjai Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-21-2009 06:38 PM
Stupid question...TRD Quick Shift Stargate YARlantIS DIY / Maintenance / Service 17 12-01-2008 12:46 AM
Quick headlight question silverRS Cosmetic Modifications (Exterior/Interior) 3 06-21-2006 10:54 AM
