Old 01-29-2011, 01:43 AM   #1
Nodrog
Nodrog's Avatar
Send a message via AIM to Nodrog
Boss HU wiring questions
I hope to install this Boss HU in my 07 sedan.
Q1-I have the Metra harness, which I have connected to one of the HU's harness. The other harness has this pink wire labeled 'Front Illumination Control (+12V)'. I'm not sure where to connect this, and the only thing I've found on the forum is this-which I have no idea what it means;
"Radio Illumination green + radio harness"
Any ideas where to connect this wire?
Q2- I have the brown 'brake' wire, which I understand from the forums can be connected to a ground instead of the brake (it's a very short wire) to be able to watch video 'all the time'. Is this correct?
Thanks so much for any help that can be offered. I was all ready to go install the HU when all the stuff arrived (bunch of eBay purchases), but this pink wire especially has stumped me...
If it aint fixed, don't broke it.
Nodrog is offline   Reply With Quote
Old 01-29-2011, 03:13 AM   #2
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
If that's from your radio harness check out the Orange wire, on the wire harness it should read illumination. Although you know the speech safety first bla bla bla if you get into an accident it's on you, but yes, you ground that wire to anywhere metal, I just put a bolt with a nut and grounded mine when i had it.
First two should match up perfect, the other is the actual factory harness color.
Old 01-29-2011, 11:59 AM   #3
Nodrog
Nodrog's Avatar
Excellent, thanks so much S7v7n! Yes, there is an orange wire unattached on the Metra harness, and I was hoping that was the one. Very nice graphical layout there. Everything matched up except an orange wire and this pink 'Illumnation' wire and an orange 'backup camera input trigger' wire...I figured the Metra harness probably didn't have backup camera wires on it, but didn't want to assume pink-to-orange either.
I have not looked at the factory harness yet, but I take this to mean the colors on the Metra harness will not match the colors on the Toyota harness when it is plugged in, since the Metra harness is meant to make the aftermarket radio easier to hook up, right?
Anyway, I am now ready to install today, yay!
Old 01-29-2011, 11:16 PM   #4
_S7V7N_
_S7V7N_'s Avatar
All them graphs are on http://www.the12volt.com/. I've just done a ton of research over the years and have found some pretty helpful sites. Glad you got the unit installed, if you need any other help feel free to ask.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack zerosktz Willing to Buy by private party 4 02-19-2011 02:41 PM
Boss HU wiring questions Nodrog In Car Entertainment + Electronics (audio / video / alarm) 1 01-29-2011 07:18 AM
Another question about car audio wiring for rear components YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 0 08-16-2010 09:39 PM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 11:43 AM
