Old 06-10-2016, 09:56 AM   #1
nkaufman
Drives: Yaris
2010 Sedan Drive Belt?
Hello,
Have a 2010 Yaris 4-door Sedan with 40K miles.
Dealer is asking me to get the "Drive Belt" replaced. Toyota maintenance does not say anything about this.
Am wondering if I should go ahead with this replacement or get a second opinion. Car runs fine. Hear no squealing noise while turning etc.
Dealer charging $160 for this.
Thanks,
nkaufman is offline   Reply With Quote
Old 06-10-2016, 10:48 AM   #2
joell
joell's Avatar
Drives: 2013 Hatchback
According to the toyota site:
"Drive Belts will last 60,000 to 100,000km with normal use, but this can vary greatly due to harsh operating conditions."
If there is no signs of noises or malfunction of any of the components driven by the belt (water pump, alternator, compressor,etc ) and there is no visual damage of the belt, then maybe is better get a second opinion just to be sure.
joell is offline   Reply With Quote
Old 06-10-2016, 11:10 AM   #3
Biginjapan13
Drives: lowered/ exhaust
A drive belt is NOT an item that can be given a time or mileage time stamp. Living in Arizona I see drive belts start cracking at 45k miles. Visually inspect the drive belt and if there are cracks closer then 1 inch apart then the drive belt should be replaced. Just because there isn't a noise doesn't mean the belt isn't bad. The last thing you want is to be driving and the belt break cause then your engine won't have any accessories moving including the water pump
Biginjapan13 is offline   Reply With Quote
Old 06-10-2016, 12:08 PM   #4
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
As a point of comparison, the drive belt didn't need changing on my 2000 Accord until around 105K miles, while I was living in Atlanta, GA. I doubt it would have fared that well out here in AZ though. I'm guessing that VA weather is a bit more harsh on a vehicle than it was in GA (particularly winters).
Kalispel is offline   Reply With Quote
Old 06-10-2016, 12:52 PM   #5
91mustang
Drives: Charcoal 2012 Yaris SE 5 Speed
It is a 30 dollar part and they are charging 130 dollars for a couple minutes install time.
91mustang is offline   Reply With Quote
Old 06-10-2016, 01:18 PM   #6
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Mine was cracking. I was going to have it replaced until I saw the $130 price the dealer wanted. My part? $18. It took me 30 minutes to do myself.
Old 06-10-2016, 01:33 PM   #7
bronsin
bronsin's Avatar
$160 for an accessory belt is rape.
Check it yourself. Is it loose? Are the ribs on the inner side of it damaged or gone?
Old 06-10-2016, 04:03 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Originally Posted by nkaufman View Post
Hello,
Thanks,
20 bucks for belt and maybe 10 to 15 min in replacing ...do it yourself save the money .
Old 06-11-2016, 07:52 AM   #9
nkaufman
Drives: Yaris
That is the reason for the post. If not based time or mileage criteria, then I thought noise would be the first indicator. Are you saying that the belt could snap just like that without presenting any symptom first?
Old 06-11-2016, 07:53 AM   #10
nkaufman
Drives: Yaris
Yes, that is what I'm thinking of doing.
Old 06-11-2016, 07:54 AM   #11
nkaufman
Drives: Yaris
As is most service performed by a dealer.
Old 06-11-2016, 09:45 AM   #12
Biginjapan13
Usually belts do make noise when they go bad, but there are sometimes that they don't. You said it didn't make noise when Turing the steering wheel but if I'm not mistaken you car has electronic power steering and there is no power steering pump. So even with a bad belt turning the wheel wouldn't create a noise with the belt anyhow. On the other hand just because it makes noise doesn't mean it's bad. A Yaris does not have an automatic tensioner and it the belt were to be loose (they can stretch) that could also make noise. If you could post a pic of the ribs on the drive belt I'm sure we could tell you if it's bad or not
Old 07-04-2016, 01:16 PM   #13
nkaufman
Drives: Yaris
Belt pics
Hello,
Attached are some pics. Do not know if I captured the condition of the belt properly enough. Please let me know.
Old 07-04-2016, 01:22 PM   #14
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
In the middle and last pic one can see cracks, also belts are cheap and so easy to change on a Yaris yourself...so why risk it just pick up a belt also if get it from Toyota just ask the parts guy to print off how it goes on.
This way you won't make a mistake, all you need to do is loosen the bolts on the alternator .
Sent from my ONEPLUS A3000 using Tapatalk
Old 07-04-2016, 02:39 PM   #15
nkaufman
Drives: Yaris
Thank you for looking at the pics.
I couldn't see any cracks on the belt similar to what mention and am wondering if you could point those areas in the picture.
Old 07-04-2016, 03:18 PM   #16
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
From what I can see in the picture belt looks good to me.
Old 07-04-2016, 04:40 PM   #17
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
The cracks are visible on the inside the rib part of belt, that belt needs replacement.
Old 07-07-2016, 05:11 AM   #18
nkaufman
Drives: Yaris
I'd asked before but asking again.
For my knowledge (and others on the forum), could you please point out the spots that show these cracks on the picture?
Thanks,
Drive Belt replacement nkaufman DIY / Maintenance / Service 6 03-14-2015 02:13 PM
Drive Belt Replacement wagon DIY / Maintenance / Service 2 12-28-2014 11:24 AM
OCV or VVTI Solenoid.. Drive Belt Change Yar Is Thy Name DIY / Maintenance / Service 9 12-12-2014 12:44 PM
Increased ground clearance between 2008 and 2010 Sedan unclenefeesa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-17-2013 05:49 AM
