Old 10-01-2011, 08:35 PM   #1
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Bury a key in the dash
Hi all...I just installed a remote starter...but since I have an immobilizer...I must install a bypass module or I can bury a key in the dash...
A friend of mine gave the remote starter to me...and I dont want to spend money for the bypass so It would be all FREE
And I don't really know where to put the key in the dash so the immobilizer see the key....
Can someone help me ? :)
Interior:ALL red, black roof
Old 10-01-2011, 10:09 PM   #2
In the days before bypass modules, people bought the little boxes that had a coil around the key inside. That allowed you to bury the "key in the box" deep in the dash. If you want to skip the bypass module, you will need to put the key very close to the coil, which surrounds the ignition switch, which probably means right under the steering column cover, taped to the ignition switch assembly. If you are going to do this, you may want to cut the key portion off of the head, and just put the head in there, so the steering column can not be unlocked with it.
Old 10-01-2011, 11:02 PM   #3
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
... or I can bury a key in the dash...
That's a really good idea. And as usual CTScott has the answer. I have 3 keys for my car, 2 normal (black head with remote buttons) and a Valet Key (grey plastic head - non remote). Can the Valet key be used to trick the immobilizer to avoid butchering a normal key, or would I have to use one of the normal keys?
Stove is offline   Reply With Quote
Old 10-01-2011, 11:08 PM   #4
Valet would be fine.
Old 10-03-2011, 07:11 AM   #5
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
we usually use a corresponding key but leave it blank as there is no need to cut it. a/v guy just programs and hides away....
Old 10-14-2011, 03:08 PM   #6
packetrace
packetrace's Avatar
i just put the key there ? no wire no thing ?....pictures please ? :)
Old 10-15-2011, 08:34 AM   #7
ROCKLAND TOYOTA
TRIM HUNTER
^^ you have to program key which for me requires a techstream computer that mechanics use....
2007 Yaris: looks like I only have a "valet" key. Options? choppa DIY / Maintenance / Service 11 11-21-2016 10:23 AM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
2010 Yaris Sedan - Need Key Programmed to the Immobilizer vst General Yaris / Vitz Discussion 0 04-17-2011 04:29 PM
Reemplazo Swichera yukardo Central and South America 3 04-03-2011 12:11 AM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
