Old 04-26-2011, 10:53 AM   #1
ImDrinkingWindex
Drives: Yaris
Will Nokya/Luminic/Silverstar Headlight bulbs burn my wires?
Hey all,
Sorry if this question is common sense but I just wanted to ask to be completely sure before I buy a new set of bulbs. I was looking to change out my OEM headlight bulbs for something new.
Luminics Ultra White H4/9003 Halogen 5150K Headlight: http://www.amazon.com/Luminics-Ultra...3828680&sr=1-2
Nokya Arctic White: http://www.amazon.com/Nokya-Halogen-...3828823&sr=1-4
Nokya Cosmic White: http://www.amazon.com/Nokya-Cosmic-H...3828823&sr=1-8
Silverstar Ultra: http://www.amazon.com/Sylvania-9003-...=pd_sbs_auto_4
I've read that some people have issues with the wires burning, can this potentially be a problem later down the line for me if I use Nokya/Luminic/Silverstar bulbs? I noticed that the Nokya's use much more wattage than the other two, does this affect/risk anything?
Does anyone have any experience with these bulbs? Recommendations?
Thanks for all the help, I'll check back asap!
ImDrinkingWindex is offline   Reply With Quote
Old 04-26-2011, 11:12 AM   #2
I have been running Silverstar Ultras for over 2 years now and my headlight connectors are not even discolored.
You do need to be careful with higher wattage bulbs, as they will generate more heat. The headlights are fused at 10A per side, which theoretically means that they can handle between 120 and 140 Watts per side as far current flow goes. As far as heat dissipation goes though, they can't handle anywhere near that much. I don't know what the actual limit is before the connector, wire insulation or plastic housing begins to fail.
Old 04-26-2011, 12:02 PM   #3
Hershey
SILVERSTAR or the ULTRAs no . The downfall is they only last up to a year and a 1/2 . Less if the car has daytime running lights . Still well worth the money thanks to whiter light that helps distinguish critters of the night . Especiallly deer . Have them in the '08 sedan . SYLVANIA sometimes has rebates of $5 for the Silverstar and $10 for the Ultra at their website .
Old 04-26-2011, 12:26 PM   #4
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Just check the wattage/volts as long as they are what the stock bulbs are, you'll be fine.
Old 04-26-2011, 12:56 PM   #5
just get hid's...
Old 04-26-2011, 09:27 PM   #6
ImDrinkingWindex
Drives: Yaris
Nokya: # Model: H4 / 9003
# Output: 12V 90/100W
Luminics: * Model: H4 / 9003
* Output: 12V 60/55W
* 5150K Color output with same wattage as your Factory light bulb.
Silverstar: 128V, 60/55W
Does anyone know what the V and W are for the stock bulbs? I'm not too sure where to find out.
And if I buy some dielectric grease, where do I apply that when installing new bulbs?
Thanks for the replies guys!
Old 04-26-2011, 11:20 PM   #7
carnageehw
Drives: 2010 Fusion Hybrid
It'll annoy every other drive on the road, though.
carnageehw is offline   Reply With Quote
Old 04-27-2011, 08:06 AM   #8
W is the power consumption (in Watts) at a particular voltage (V). The OEM bulbs are 55W for low and 60W for high beam, like the silverstars. For the silverstar, the rating is probably 12.8V, not 128V. The two numbers for the wattage are high and low beam power draw.
The dielectric grease is used on the contacts to keep moisture off to keep them from corroding.
Old 04-29-2011, 08:21 AM   #9
ImDrinkingWindex
Drives: Yaris
Ah I see, I'll probably stay away from the Nokya bulbs then because of the wattage.
Anyone have any experience with the Luminics bulbs? I can't decide whether or not I should pick up a pair of Luminics or Silverstar ultras.
For anyone that has Silverstar ultras, is the light completely white or does it have a bit of a bluish tint to it? I'm looking for a bulb with a slight hint of blue but not so much as it being illegal in Hawaii and me being pull over for them. I've been searching online and I can't find any information about the laws regarding headlights :\
Thanks again for the replies!
Old 04-29-2011, 11:54 AM   #10
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ they are white. no blue tint.
Old 04-29-2011, 12:55 PM   #11
Hershey
+1 , white .
Old 05-10-2011, 08:35 PM   #12
ImDrinkingWindex
Drives: Yaris
Thanks guys, just bought Nokya's and a wiring harness.
Old 07-08-2011, 10:07 PM   #13
ciscobear
Drives: Toyota Belta
pics?
ciscobear is offline   Reply With Quote
Problem with headlight and foglight bulbs. Yaris PAVEL94 Cosmetic Modifications (Exterior/Interior) 2 12-16-2010 10:03 PM
FS: H1 Nokya Hyper Yellow Headlight Bulbs (for Depo Projectors) 33OH Items for Sale by private party 7 11-14-2010 05:54 PM
FS: Nokya Hyper Yellow H4 - 2500K Headlight Bulbs 33OH Items for Sale by private party 3 07-15-2010 03:39 PM
RED Headlight Bulbs.... where to find? Parmas Cosmetic Modifications (Exterior/Interior) 9 04-26-2010 08:10 AM
Yellow, Purple, Green Headlight BULBS? jamal1984 Cosmetic Modifications (Exterior/Interior) 12 02-04-2007 08:30 AM
