Old 05-26-2011, 07:46 AM   #1
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
increasing sound insulation?
HAI GUYS
i'm really sick of driving in the HOT & CROWD roads of Egypt ..
I want to increase the sound (and heat if possible) insulation in my babe yaris
Any suggestions? or cheap ideas?
BLOODY_STONE is offline   Reply With Quote
Old 05-26-2011, 02:44 PM   #2
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
The cheapest option is a standalone installation of insulation.
For good materials vseravno have to pay.
MickZEL is offline   Reply With Quote
Old 05-26-2011, 10:10 PM   #3
BLOODY_STONE
k somebody tell me whati should get?
Old 05-27-2011, 10:15 AM   #4
swidd
Drives: Yaris HB
I got b-quiet for much cheaper than dynamat on eBay, its by most measurements the exact same material. It takes about 100 sq ft. to do the whole car. You don't have to do solid portions under the rear seat (no vibrations there). Suppose you don't have Home Depot, but dirt cheap rubberized roof insulation material will do the same job.
For heat problems, look into the A/C low pressure return line insulation mod.
Old 05-27-2011, 05:14 PM   #5
BLOODY_STONE
Ya i'm studying that mod r8 nw cuz someppl told me it can cause ur compressor to die out shortly!
Old 06-10-2011, 10:23 AM   #6
mhkritzinger
Drives: 1.8 3dr Yaris TS
I also am planning to do what you did on your Yaris! Just wanna know if you only put the b-quiet on the outer skin of the door or did you put it on the inside skin and outer skin of the door here the speaker is??
mhkritzinger is offline   Reply With Quote
Old 06-10-2011, 03:33 PM   #7
swidd
Drives: Yaris HB
I only put it on the outside skin, because I didn't have anything to create a wall to cover the open gaps on the inside. I should probably go fix that.
Just covering the outside makes the door have a "luxury clunk" when it closes.
Old 06-10-2011, 05:03 PM   #8
I thick coat of rubberized undercoating in the wheel wells makes a BIG difference. Very cheap project too!
Old 06-10-2011, 05:35 PM   #9
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
I just looked on ebay. I wish that b-quiet stuff wasn't so pricey, I don't even put $2.50/sqft flooring in my house, much less something that goes unseen in my car. heh
Old 06-11-2011, 11:20 AM   #10
swidd
Drives: Yaris HB
Then head to Home Depot =)
Old 06-11-2011, 12:25 PM   #11
mhkritzinger
can anyone tell me if their is an cheaper alternative to dynamat or b-quiet?? I really wanna do this to my car! and how do you close the holes inside the door? and the rubberizing of the wheel wels what kind of product can i use to do that?
Old 06-11-2011, 10:01 PM   #12
swidd
Drives: Yaris HB
wheel wells: rubberized undercoating / truck bed rubber spray. Someone also sells a anti-corrosive dense paint that you'd need multiple layers of. As cali_yaris said, it absolutely helps; I've applied more and more to finish off my sound deadening project - it isn't good enough to be the only solution, but fixing the wheel wells make a big difference in tire and rolling noise.
home depot: peel & seal. Anything that looks like it is made of rubber/a tar base dense flexible "asphalt" on one side, with fixed aluminum backing. Should also be pre-glued so it is less mess. Make sure it actually isn't asphalt...
Old 06-12-2011, 06:36 AM   #13
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Here are 29 photos on soundproofing.
Old 06-12-2011, 07:51 AM   #14
mhkritzinger
Thanx allot!! This helped me allot! So the rubberizing, I just spray it on and that alone will make a huge difference?
I will head to the home depot and get that stuff. will you be able to hear the difference between dynamat and something like this?
THanx for your help! I appreciate it!!
Old 06-12-2011, 07:53 AM   #15
mhkritzinger
Where are the photos or the link? thanx though!
Old 06-12-2011, 09:45 AM   #16
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
http://s1201.photobucket.com/albums/bb352/MickZEL/
Old 06-12-2011, 11:33 AM   #17
mhkritzinger
thanx!! awsome photos!
Old 06-12-2011, 12:42 PM   #18
swidd
Drives: Yaris HB
The rubber stuff: yes, spray it on the inside of the wheel wells, on the metal thin surfaces that cover the tires (I spray the plastic parts and suspension too, but I'm not doing it right). Be careful not to spray on the exterior paint, but hold the can far enough away to get a nice spread. Shake the can very hard for the specified time - otherwise you just get paint and glue and no rubber. Use rubber gloves or hold the can with a trash bag; it gets messy.
The difference between dynamat and b-quiet or peel and seal is not appreciable. The material is essentially the same, short of a few m.m. difference in thickness. As your stuff will be way cheaper, you can just do double layer in the middle sections of the surfaces you cover. It has nothing to do with the material really - dynamat for $600 isn't magic or superior - it is all about adding mass to prevent the sheet metal from vibrating, while getting a good glue that will permanently stick even in rain, sun, winter and extremes of either. Use a roller to press the stuff into edges and get a good stick. I think good results are more about patient and thoughtful install than thickness of the material. If you want it even more quiet, get foam, like a foam mattress, and stuff it into the door frames.
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 06:35 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-05-2011 12:56 AM
Yaris with new audio DPS module installed - Gadget or really increasing sound quality Flyingmatdes New YARIS Purchase Forum 8 04-19-2011 01:50 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 04:11 AM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 03:56 AM
