Old 01-17-2007, 10:24 PM   #1
gaf99
Drives: ?
mud sump......
Anyone noticed the huge mud sump behind the rear wheels of the Yaris - is a closure plate missing ? It has no drain hole and a capacity and shape specifically designed to trap mud/stones & crud. Are Toyota blind to such oversights ?
gaf99 is offline   Reply With Quote
Old 01-18-2007, 12:25 AM   #2
johnnyfive
johnnyfive's Avatar
i have not noticed, but i have noticed a low, almost mudflap looking plastic piece behind the rear wheeles, maybe yours is missing?
i will have to check mine closer in the morning...
johnnyfive is offline   Reply With Quote
Old 01-18-2007, 03:16 PM   #3
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
its like almost every other car out there just slightly more prevelent on the yaris. its an area you defenitely want to keep clean. after having two used cars which rusted in this area I make damn sure that area is kept clean. clean it and spray in some undercoat.
mikeukrainetz is offline   Reply With Quote
Old 01-18-2007, 07:13 PM   #4
gaf99
Drives: ?
is it easy to do the undercoat? how thick? is this something that toyota can do with one of there packages that are offered? i hate to start tinkering with stuff like this esp when it come to rust issues on a new car. will mud flips help? i have not seen the area that we are talking about but i am concerned b/c i will be in the market to buy one in march and don't want to be hassled with this.
Old 01-19-2007, 08:40 AM   #5
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
I wonder if you could clean it really well and carefully fill the areas with "Great Stuff". Then use undercoating to seal everything.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 01-19-2007, 05:27 PM   #6
mikeukrainetz
thatll work too so long as the foam doesnt work itself loose.
its easy to undercoat this area, just do an exceptional job cleaning the area with a brush and soap, rinse clean. Tape the leading edge and portion of the the outer fender to prevent overspray and spray away. You can get aerosol cans of undercoat at pretty much any auto store - it gets everywhere so be carefull.
while your at it you might as well do the whole inner wheel well - chris had a good DIY for this.
the area btw is right infront of the rear tire
Old 01-19-2007, 09:01 PM   #7
gaf99
Drives: ?
do you have to undercoat or will just cleaning it weekly prevent rust?
Old 01-21-2007, 01:49 PM   #8
mikeukrainetz
keep it clean is fine, after a while though it tends to slip the mind. $5 worth of undercoat is just better insurance and piece of mind.
Old 01-21-2007, 03:09 PM   #9
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
There is a lot of space down there.Tha undercoat is a great idea.
Mud Guard: To paint or not to paint Joel Leong Cosmetic Modifications (Exterior/Interior) 11 07-20-2011 04:25 AM
Brand New Mud Guards for Liftback Violin Items for Sale by private party 2 01-04-2007 06:54 PM
Toyota Mud Guards Violin Cosmetic Modifications (Exterior/Interior) 12 10-25-2006 08:10 PM
Mud Gaurds..Help PixieDawn Cosmetic Modifications (Exterior/Interior) 23 09-10-2006 03:29 PM
