Old 07-30-2013, 11:20 AM   #1
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
obd2 scanner....
anyone know what protocol os 2001 vitz 1.0 auto, japan model is?? i screwed a lot of money on obd2 scanners....3 scanners and everytime tells me link error. im gonna piss out ...it drive me crazy. pls any help?
dindy is offline   Reply With Quote
Old 07-30-2013, 02:27 PM   #2
From what I have seen it is supposed to be ISO 9141 compliant.
Old 07-30-2013, 02:55 PM   #3
dindy
yeap it is. but it wont link. but now i notice something in this scanner. i found a pending code. p0172. im not sure if it was saved in the scanner. is it possible that the scanner detected something? even if the scanner it does not linked??
Old 07-30-2013, 03:51 PM   #4
That may be possible. The scanner may be trying to also maintain a communication stream that the ECM does not support.
Old 07-30-2013, 04:10 PM   #5
dindy
thanks scott. dont know why it wont link. 3 different obd scanner..
Old 01-05-2014, 09:45 PM   #6
arv784
Drives: 2001 Toyota Vitz RS
Hey Dindy,
Did you have any luck in finding a reader that links with your Vitz. I have been getting the check engine light on my Vitz lately, but the garages here charge an arm and leg for reading the code alone. So I thought it best to just get a reader, but I can't find any concrete source indicating what protocol the Japanese 2001 Vitz uses.
So far my best bet is the ELM327 OBDii - OBD2, which says the Japanese Yaris is compatible: http://www.adverts.ie/car-parts-acce...canner/2733586
Did you try this one by chance? Let me know. Thanks buddy.
arv784 is offline   Reply With Quote
Old 01-07-2014, 12:15 AM   #7
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
JDM cars don't support OBD protocol from my experience. I bought an ELM327 scanner and it refused to connect to my Vitz. I've ordered a Toyota Techstream scanner and I'll see how that goes.
JudgeM is offline   Reply With Quote
Old 02-24-2014, 04:23 PM   #8
dindy
no luck still now.. still check engine light went off
but i like to know with scanner does communicate with my vehcile
any one?
Old 02-28-2014, 04:19 PM   #9
JudgeM
JudgeM's Avatar
ELM327 cannot work with JDM Vitz, whatever the advertisements say it wont work. Yes the protocol is supported but the way the ECU talks to the software is the problem.
Toyota techstream scanners work with JDM Vitz, and the more expensive JOBD scanners.
I was really disappointed with ELM327. I really wanted Torque in my car, I already bought the app and almost bought a tablet so I can have it permanently in my car.
Old 02-28-2014, 05:06 PM   #10
If I can get my hands on a Vitz ECM, I am going to build an ELM327 compatible device to work with the MOBD protocol, which the JDM cars support.
Old 03-01-2014, 05:48 PM   #11
JudgeM
JudgeM's Avatar
I will be your first customer :D
Old 03-01-2014, 06:17 PM   #12
OK. Then, find me a cheap ECM in a junkyard over there. I actually had a JDM one and a while back I harvested parts off of it, as I didn't think I would ever need it for anything.
Anyone have a Gopoint GL1 OBD2 scanner? jayeh General Yaris / Vitz Discussion 5 02-25-2012 12:02 AM
How to Reach Trouble Codes without Scanner? tahir44 General Yaris / Vitz Discussion 5 04-19-2011 09:55 AM
Actron CP9135 Scanner regal DIY / Maintenance / Service 6 11-08-2009 11:29 PM
Bluetooth CAN OBD2 Wireless reader for labtop or other bluetooth device $75 YarisSedan Items for Sale by private party 1 01-22-2009 06:18 PM
