Old 09-30-2011, 02:30 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
changing fuel filter
07 hatch 1.5 manual
I got the bottom seat out and I see the round spot welded port with the 3 wire coming out of it. I assume this is the fuel pump wires/no?????
Do I pop off the rubber grommet to find the fuel filter down in there????
what is the best source for a fuel filter /aftermarket for this and any tricks for getting new one in???? thanks
yaris9876 is offline   Reply With Quote
Old 09-30-2011, 02:47 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
FYI: i have NO listing for a fuel filter NOR do i see one in my catalog pictures.....
Old 09-30-2011, 03:20 PM   #3
BLH
Drives: 2007 Yaris Sedan
The 2007 Service Literature is linked here.
http://www.etimago.com/yaris/repairmanual/
You may want to look at the Fuel System part.
BLH is offline   Reply With Quote
Old 09-30-2011, 03:27 PM   #4
Toyota only sells the fuel filter attached to the pump. Beck/Arnley makes a replacement for the OEM filter and Rock Auto sells it for $20:
http://www.rockauto.com/catalog/x,ca...,parttype,6200
Old 09-30-2011, 09:20 PM   #5
yaris9876
i popped the grommet and only see wires......where is the fuel pump and filter on the hatchback??? anyone done this??
Old 09-30-2011, 09:22 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Its part of the pump. Its considered a non serviceable item. There should be no need to change it unless its clogged and causing low fuel pressure.
Old 09-30-2011, 09:24 PM   #7
This post has a pic of it (1st pic). You have to remove the top of the gas tank (2nd picture) to pull the sender unit out. The pump is mounted inside of the sender and the filter is clipped to it.
http://www.yarisworld.com/forums/sho...90&postcount=3
Old 10-01-2011, 09:53 PM   #8
yaris9876
so you have to pull the tank down...what a bunch of shit...
Old 10-01-2011, 10:03 PM   #9
No, you don't drop the tank, You remove the access panel inside of the car, and then remove the top of the tank and pull the sender unit out the top.
I pulled my tank when I got at mine because I was doing a little welding back there and didn't want to risk lighting the tank on fire.
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 11:05 AM
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Fuel Filter abbeyaris General Yaris / Vitz Discussion 35 03-22-2009 11:40 AM
