![]() ![]() ![]() Drives: Miss my Yaris, love my Jeep jk Join Date: Aug 2011
Suspension creaking
My 2011 3 DR LB, (automatic) has developed a creak in the right rear when I stop abruptly enough to cause the rear suspension to raise up a bit from the forward motion.
The creaking occurs when the rear of the car "settles" back to it's normal posture immediately after the stop. Sounds like something needs lubricated....its brand new...1,800 miles. Any insights? |
try some lubercation on the rubber seats on the springs maybe?
double check all your bolts too.. one could have come loose just a little bit. just some suggestions
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
I've got the same issue on my 07...just been too lazy to do anything about it. I'll probably get around to poking around back there shortly.
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
seems like my whole suspension system creeks when I go over speed bumps... front and back. Was hopeing when I change out my springs this weekend that would stop.
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
![]() Drives: red 5 door aotomatic Join Date: Sep 2011
Use some silicon spray on all the pivot pts in the rear,most jts are assembled dry and they just stick to bolts or shafts they ride on,try to do it with the susp unloaded.,jacked up car and wheels hanging.![]()
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
It is not your suspension. It is your brakes.
Remove the drums, lubricate the sections of the shoes where they slide on the back plate as well as the pin at the very bottom opposite the brake cylinder (cylinder on top @ 12:00, one single large pin on the bottom @ 6:00). The pin is a large (1/2" diameter maybe??) which both shoes "pivot" on. You may want to blow the dust off the springs and give them a shot of dry lube also. If you let it get worse, you will be able to hear the "squeak" when you take your foot off the brake pedal and the shoes retract. |
#7 | |
Depending on the miles, is it under 40k still? I would say this is a warranty issue also.. take it to the dealership and have a service writer ride with you to confirm the noise. If they agree that there is an issue, then they should take care of it. If it is the brakes, let the toyota guys get thier hands dirty and save you the headache
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
We have the same noise from the rear of the driver side of the '08 sedan .
Dealer
Has anyone who has replied and/or had a similar problem had their dealer look into this? Just curious...sounds like a common-ish quirk to the Yaris.
(I'll spray something on the rubber-to-metal areas back there only because it takes about 30 seconds, but after that it's going in. I'm fresh off the lot with 34 months of warranty ahead) |
#10 | |
advocatus diaboli
In my case, it's not the brakes...I know the difference between the two, and I've already fixed the brake noise on mine(for the time being). OP, don't go taking your brakes apart just yet...
#11 | |
The noise happens after the stop (split second), when the vehicle wants to roll backward while the brakes are engaged and the shoes shift. However as mentioned.. New car (2011) still under warranty, take it in. |
advocatus diaboli
I can hear the two noises, and tell the difference between them...maybe mine is worse off then yours.
Drives: Yaris Sedan 2007 Join Date: Dec 2011
Total newbie here. I have a 2007 Yaris Sedan and the entire under carriage sounds like it's going to just crumble in a million pieces. I hear it the worse when I go over speed bumps. I just assumed that I needed to crawl under there and tighten whatever bolt I saw. I changed the front pads recently but I haven't touched the drums.
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 09:26 PM |
| NSW Proposed Suspension Restrictions | Bella | Australia | 0 | 09-22-2010 01:51 AM |
| My suspension setup: Breakfast Blend for the angry panda | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 07-26-2010 03:56 PM |
| Tein Basic Compact Suspension for SALE!! | 33lam | Australia | 14 | 04-17-2010 08:24 PM |
| Any Yaris hatch rear suspension tweeks? | woof | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-05-2009 06:04 PM |
