Old 12-20-2011, 03:35 PM   #1
revolution
Drives: 2009 JDM Toyota Vitz
Headlamp Conversion
Hi,
My 2008 Vitz RS was front-ended by a suicidal cyclist whilst parked, and both my front headlamps have been damaged, along with the front bumper. i'm taking this opportunity to have Insurance (Ahem!) convert me to the 2010 Front Bumper and i have to change the headlamps as well, due to the facelift where the headlamps have a little bulge on them towards the grille... (which my old headlamps dont have)..
My question is, that as my Vitz RS has the OEM Toyota HIDs with separate Dim and Bright Bulbs, can i gut the inside bulb mounts and chrome reflector and trnasplant it into the 2010 headlamps? I really dont want the H4 setup from the 2010 headlamps, would rather retain the 2008 OEM HIDs...
I haven't disassembled headlamps before so im hoping someone out there may be able to tell me if this may be possible to do, or if the bulges on the headlamps will mean it wont fit...
2011 JDM Toyota Vitz RS
NCP91-AHMVK
Keyless-Go,8 Airbags, Pioneer AVH-P4150DVD, Reverse Camera, Nokia Bluetooth Kit, Pioneer 6.5" 230W Split System in Front, 6000K HIDs in Headlamps, 6000K HIDs in Foglamps, Afe Intake, 17" Advanti Toro Rosso Alloys with 205/45/17 Yokohama R1 Tyres, 40mm Modellista Lowering Springs...
revolution is offline   Reply With Quote
Old 12-20-2011, 03:50 PM   #2
djct_watt
Drives: 2010 NCP91 5spd
When it comes to retrofits, anything is possible with time and skill. Sorry if that answer is not very helpful. I'm sure someone w more experience will chime in. But to keep the light dispersion and cutoff, you will need to transplant the entire reflector bowl, which will be a slight different shape between the two headlight styles. I have no idea if the differences are small enough for any easy retrofit. IMO, it might be easier to just to a projector retrofit.
The best modification you can make is between the steering wheel and driver's seat.
Old 12-20-2011, 03:54 PM   #3
revolution
Thats what i was thinking - transplanting the entire reflector bowl to the new headlamp, but not to sure if it is actually removable from the plastic part of the headlamp...
NCP91-AHMVK
Old 12-30-2011, 02:38 PM   #4
SAV912
Pirate Yaaaaris
SAV912's Avatar
In order to do a retrofit for projectors, you have to remove the plastic shell from the bowl anyway, and there's proof that people have done that. The difference in your case would be getting a 2010 plastic shell with the curve on the inner edge to fit over a 2008 reflector bowl. And without some epoxy and lots of silicone sealant, I don't see that happening.
There really aren't many differences between the two front ends. Unless you're getting the full S treatment, why are you bothering with the 2010 conversion? I'd stick with the 2.0 gen, rather than the 2.1, especially if there are OEM HIDs involved.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
One filament in the headlamp bulb. ellenbetty General Yaris / Vitz Discussion 7 09-06-2009 01:30 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
2009 Front Bumper Conversion with foglight 808yarisLB Cosmetic Modifications (Exterior/Interior) 25 01-03-2009 12:47 AM
