Old 12-11-2011, 12:25 PM   #1
bankrobber
Drives: 2007 Yaris Hatchback
belt slipping
Replaced serpentine belt 3 months ago and it is starting to slip at start-up. Especially wuth A/C turned on. I dont think I got belt tight enough when I replaced it as I was afraid of it being too tight and burning up water pump or alternator. I have 130k miles still origional water pump and alternator
bankrobber is offline   Reply With Quote
Old 12-12-2011, 08:33 AM   #2
Jedz123
Two Wheeled Fiend
Drives: 08 Yaris 2D Lftback 5-speed
How much slack do you have? Did you accidentally get any grease or oil on the belt or pulley? Yeah you can over tighten belts but you really don't want room for slack. I always tighten mine until there is just enough tightness so there inst any slack. If it squeaks I'll tighten the bolt a 1/4 turn each time with the wrench until the belt stops slipping. However first step is to make sure the pulleys and belt are clean and free of oil and grease.
2008 Suzuki B-King
2001 Yamaha FZ1 (2005 motor swap)
1998 Suzuki Bandit 1200S
1983 Suzuki GR650
2008 Toyota Yaris 2DR HB (The Cage)
Jedz123 is offline   Reply With Quote
Old 01-01-2012, 10:49 AM   #3
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
yeah sounds like you just need to tighten it a little.
198K Miles
N9QGS is offline   Reply With Quote
Old 01-02-2012, 01:23 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
Snug it up. It has likely just experienced some initial stretch which needs to be taken up.
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
Need new Serpentine/Auxilliary belt ras3448 DIY / Maintenance / Service 21 07-16-2013 05:11 PM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
squeaky belt TickleTimeTim DIY / Maintenance / Service 14 03-16-2011 11:49 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
