Old 08-06-2013, 12:56 PM   #1
yarismo
yarismo's Avatar
Drives: Yaris HB luna
Auris engine
Hi, may be this will sounds strange, but i wonder if the Auris engine 1.6 can fit a 2006 hb yaris 2nz-fe !?!
yarismo is offline   Reply With Quote
Old 08-06-2013, 05:42 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Fit? Sure! Easy? Probably not...
Old 08-06-2013, 05:43 PM   #3
Specs. Please.
Old 08-06-2013, 07:37 PM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
better to do the auris 1.8.
Old 08-06-2013, 08:59 PM   #5
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
1ZR-FAE
The Toyota 1ZR-FAE is a DOHC, 16-valve, 1.6 L (1,598 cc) engine also equipped with Dual VVT-i and Valvematic. Output for this engine is rated at 132 hp (97 kW) at 6400 rpm and 118 lb·ft (160 N·m) of torque at 4400 rpm for the Avensis. Compression ratio has been increased to 10.7:1, red line is at 6600 rpm. Valvematic varies the intake valve lift between 1mm and 11mm according to load and RPM.
Ryze268 is offline   Reply With Quote
Old 08-07-2013, 03:43 PM   #6
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
1.6 with 130hp.... wow
Old 08-07-2013, 10:16 PM   #7
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
That's a big waste of cash.
monchito18 is offline   Reply With Quote
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
