Old 02-15-2012, 02:20 AM   #1
matthewai
matthewai's Avatar
Drives: it is kinda stock
regular/hard "spirited" driving maintenance
say one drives "spirited" as some may say, or drives "hard" if you will. what are some things to check to keep the yarii running at peak physical condition? (ie: fluids, wheels, tires, bolts, connections, engine, bolt connections ect...)
**as in any certain "problem" areas that may or may not need more attention than others (mostly bolts that could potentially loosen and cause major problems)
** just wondering for the sake of others obviously **
dont take this post the wrong way i know ill get shit for this hahaha
at least im covering all my bases
Old 02-16-2012, 07:21 AM   #2
I would just check everything more often. So that means, oil level and other fluid levels, tire pressure, alignment, tire wear, lug nut torque specs, everything.
Old 02-16-2012, 08:12 AM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
I'm that person that "drives enthusiastically" 90% of the time. Def check oil levels since there will be more blow-by. Check everything sooner. I go through tires yearly (balance them every 4-6mos!), and clean my intake yearly. My tranny oil gets changed very very often, and radiator fluid change every 15k. Oil every 5k. I also get stuff to keep the pressure up in the radiator and engine oil dept. Always listen for suspension sounds, especially when you live in my area..Lower CT and NY roads are ass. Driving the misc parkways does a number on your suspension with plenty of potholes and sudden crests and unavoidable dips. Higher speeds do harsher things for your suspension. Also leave the vent on and take in those misc smells!
basically yes check things more and be more aware of how the car behaves.
-Drive at 90 or get run over by that Navigator and every Audi that's on your ass in both lanes. -_-
Old 02-16-2012, 09:08 AM   #4
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i just check oil weekly and change seasonally. also weekly checks include tire prerssure and wiper fluid with an inspection of bars underneath for loose bolts. i used to be hella meticulous with the car until some douche hit me and now its just a beater until i can unload it........
Old 02-17-2012, 02:26 AM   #5
matthewai
matthewai's Avatar
thanks guys great info i do check the tires pretty much everytime i get in the car but yeah i guess i was mostly worried about the bars and springs but all seems fine after driving "enthusiastically" ahha i need to clean my intake maybe even the maf dont know if its that necessary though. gonna take it in for oil in a month or 2 and check the trans and other fluids as well
Old 02-17-2012, 09:29 PM   #6
matthewai
matthewai's Avatar
also i was wondering how good are the stock belts ? those will most likely last a while or no?
Old 02-18-2012, 10:47 AM   #7
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
I got 50k and still have OEM battery,water pump,and belts.although I did notice a belt squeal briefly upon start up the other morning.also I just cleaned trd filter after 49k and have found out why my ass dyno was indicating something was off. As for maf I would leave it alone until it throws you a code.....
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 02-18-2012, 10:55 AM   #8
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
I am changing tranny fluid again with some more redline seeing as it's been 45k since last time. One area that does suffer from abuse is the clutch in this POS which is one reason I want fluid refreshed. I'm having to engage clutch much much higher than normal and 2nd gear starts are almost like 1st on occasion which means it's tear down time or unload it like I want to....
And YES I am aware that a fluid change is no substitute for a new clutch!!!
"5 Driving Myths That Cost You Money" PETERPOOP Fuel Economy Forum 10 05-24-2011 11:20 PM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 10:00 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 08:54 AM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 06:26 PM
