Old 04-09-2012, 01:28 AM   #1
zkar
Drives: Yaris HB 2007 4 doors
205/50 R17X7" ET 42'
Hello,
I decided to use a set of 205/50R17 on my 2007's Yaris with stock suspension. Wheels are 17x7" ET 42'.
My problem is that when I turn at full, the front tire rubs on the inside face at the back.
I am considering spacers to solve the issue, but wonder if 5mm will be enough or if I should go all the way with 10mm.
Any comment/help? Thanks in advance!
zkar is offline   Reply With Quote
Old 04-10-2012, 12:47 PM   #2
zkar
OK, I got generic 10mm spacer and tried them on, looks that this will solve the rubbing issue, but now I will have to replace the studs.
Can any one let me know what are the correct studs I need?
Thanks!
Old 04-10-2012, 12:49 PM   #3
zkar
Searching around I found these:
http://www.napaonline.com/Catalog/Ca...196_0331705116
Will they work?
Thanks!
Old 04-10-2012, 12:51 PM   #4
33OH
Drives: '08 Yaris
You will need 12x1.5 studs, and the ones you cited above are 12x1.5. So yes they should work.
Not sure what type of spacer you have, but if the studs aren't in the spacer itself you will need longer studs.
Old 04-10-2012, 12:57 PM   #5
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I thought for 5/10mm spacers, studs werrn't necessary?
Old 04-10-2012, 12:58 PM   #6
5mm not necessary.
10mm absolutely necessary.
Old 04-10-2012, 01:04 PM   #7
zkar
Thanks 33OH,
Spacer I got didn't have the studs on it, they are just something like this
So does the one at NAPA looks good in both ends?
Thanks!
Old 04-10-2012, 03:04 PM   #8
33OH
Drives: '08 Yaris
5mm not necessary.
This. Anything over 5mm (7mm at the MOST) you should really look into getting longer studs.
Old 04-10-2012, 03:30 PM   #9
Will they work?
Thanks!
That is the same part# for the extended studs I got from NAPA to put 10mm spacers in my rear.
If the Yaris uses the same studs front and rear, then those will work.
Old 04-10-2012, 03:32 PM   #10
1.5
Form>Function
1.5's Avatar
Thanks for clarity
Old 04-10-2012, 03:34 PM   #11
Thanks for clarity
Yeah. 10mm on stock studs = 3 exposed stud threads. Not good.
Old 04-10-2012, 03:42 PM   #12
33OH
Drives: '08 Yaris
Yes, it does use the same studs. Thanks for checking that out. Yes - these will work!
Old 04-10-2012, 04:00 PM   #13
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm more amazed that a Yaris with 25.1" wheels can even move! My 205/50R15's are slow compared to my skinny winter tires (175/70R14).
Old 04-10-2012, 07:59 PM   #14
kimona
kimona's Avatar
Drives: 2014 White VITZ
I run 16x7, ET42 with 205/50/16's and they rub the plastic fender liners at full lock... a maneuver I've made only a handful of times in the 5 years I've been running this size tyre. Nothing for concern here.
Old 04-10-2012, 09:45 PM   #15
Yaristeve
Drives: 3-door hatch
Why not adjust the steering stop to prevent full lock? I know you will increase turning radius but you don' want to get the tight radius anyway since it will cause the tire to rub...
Oh, BTW, I was planning to go 16 X 7, 42ET with 195/50-15...
Old 04-12-2012, 06:19 AM   #16
zkar
Thank you both!
205/50 R17X7" en Yaris HB 2007? zkar Central and South America 0 01-11-2012 02:26 AM
15x7 Kosei K1 with 205/50 Yokahama Sdrives,Ultra Racing 23mmrear swaybar, Tachometer DeathBeard Items for Sale by private party 24 11-29-2010 10:13 AM
slightly used 205/50/ 15 Falken Ziex 502 tires. marlondog Items for Sale by private party 18 11-30-2009 09:43 PM
205/50 in front, 195/55 in back? ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 05-11-2009 10:11 AM
