Old 06-15-2012, 09:59 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
that is it time to lighten the load
removing the back seats for both weight and so that I can say that I can't put anyone in the back because I don't have any seats.
Old 06-16-2012, 02:21 AM   #2
very easy way to lose a pretty large amount of weight!
Old 06-16-2012, 02:28 PM   #3
Klink10
Klink10's Avatar
Originally Posted by TPA5 View Post
How much weight do you drop with ditching the rear seats? I've been debating it, but every now and then I do need to fit more than 1 passenger in my vehicle. Is the weight drop noticeable?
Someone on the forum did a weight loss thread. I think it's around 90 lbs.
Old 06-16-2012, 04:29 PM   #4
Golddeenoh
Golddeenoh's Avatar
the torques bits kicked my butt so I don't think I will be getting them out today as I had planned. but i did debadge :D
Old 06-16-2012, 07:08 PM   #5
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
^^^ lol, that did drop a little weight (much stress on the "a little")
Old 06-17-2012, 10:05 AM   #6
Golddeenoh
Golddeenoh's Avatar
well I went to Harbor Freight and got the E bits so that I could get the seats out so now they are out and some extra stuff I had back there. I left the spare and the right bin so that I could keep the jack and two equipment in the car.
Old 06-17-2012, 10:38 PM   #7
mr_miles
Drives: 2013 Yaris
my weight guestimate was 55 pounds for the large section, and 45 for the small. my scale is inaccurate and never gives the same reading. but between 90 and 100 pounds seems to be about right.
Old 06-18-2012, 12:14 AM   #8
I used a postal grade weighing scale when I first removed my back seat, if I recall correctly the back section was almost 40kg and the seat 12 or 13, so that's about 100lb indeed :) Plus a few more if you remove the bottom frame thing that stays bolted into the floor
Old 06-18-2012, 12:31 AM   #9
mr_miles
Drives: 2013 Yaris
the spare tire and cover weigh a pretty hefty amount also.....i vaguely recall the cover weighing in at 12 pounds?
Old 06-18-2012, 12:10 PM   #10
Golddeenoh
Golddeenoh's Avatar
left the spare tire, mostly because I expect I would get a flat if I took it out. I also tested the weight difference on a lot of dirt road(I hate Dirt Roads) the weight reduction was noticeable and the rear end was noticeably lighter. I actually went from a good sped on pavement to suddenly being on a dirt road as I rounded a corner, luckly I have experienced problems like that before in other vehicles so I managed to save it, but not before my wife about lost it thinking where going to crash. needless to say, If I am going to go rallying about I should get some dirt tires :D
Old 06-18-2012, 01:12 PM   #11
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Removing everything from the rear really changes the handling. Very entertaining.
Colin Chapman disciple
Old 06-19-2012, 08:30 PM   #12
nookandcrannycar
I haven't removed my rear seats, but I like your conclusion on this. My reasoning though, might be considered near the height of cynicism. I don't want the extra weight to reduce my MPG and I don't want to populate the rear seats with potential litigants should an accident occur. My only rear seat occupant has been my little cousin, first in her car seat and then later in her booster seat (before she met the weight, etc. requirements).
Yaris at Summit Point Time Trials Redbat01 Tracking, Racing, Auto-X Forum 1 05-06-2010 12:30 PM
Time Attack Invades Houston! Rollmodl Southwest 8 05-03-2010 08:00 PM
First time AutoX with the Yaris Keith Tinari Tracking, Racing, Auto-X Forum 52 11-20-2009 02:38 AM
Texas Time Trials on October 4th @ Mineral Wells ozmdd Tracking, Racing, Auto-X Forum 1 10-05-2009 01:25 PM
time zones Sodium Duck Suggestions - Feedback - Questions 13 01-06-2009 08:23 PM
